Auto Trans Troubles
Old Feb 8, 2008 | 08:43 AM
crawlin's Avatar
Default Auto Trans Troubles
Im replacing an auto trans in a 95 integra. Basically i cant get the trans to come away from the block. Ive removed all the bell housing bolts, ive disconnected the small bracket from the trans to the block on the trans side. I unbolted all the mounts the main pass side mount, torque mount, and the rear mount. The only thing i can really think of is i left the rear t mount bolted to the block and just disconnected it from the trans. I think maybe it could be being held in from that? So im kind of looking for some common things i might have missed or if you guys had an ideas. Ive only done one other auto trans, oh yeah i also disconnected the torque converter as well and the small misc stuff sensors,cooling lines etc.....
let me know what you guys think
Old Feb 9, 2008 | 02:53 AM
slowcivic2k's Avatar
Default Re: Auto Trans Troubles (crawlin)
That T bracket is a pain in ones rear. Take that out, and use a soft mallet to tap it away from the engine. Make sure you put a jack under the engine. Use a piece of wood and newspaper to prevent denting.
Old Feb 9, 2008 | 06:21 AM
crawlin's Avatar
Default Re: Auto Trans Troubles (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">That T bracket is a pain in ones rear. Take that out, and use a soft mallet to tap it away from the engine. Make sure you put a jack under the engine. Use a piece of wood and newspaper to prevent denting.</TD></TR></TABLE>
Thats basically what i planned on doing is taking that t-bracket out, i just wanted to see if there was anything i was forgetting. I got the jack and 2x4 part down, ive done quite a few manual transmission's i just dont do auto's much lol
Aqualite_Solid
Apr 17, 2011 04:54 PM
niceguyjp2183
Apr 5, 2006 04:19 PM
lastturn
Apr 23, 2005 07:13 PM
05 600RR
Apr 24, 2002 03:50 PM
