help how to weld diff on b16 tranny
Old Feb 8, 2008 | 08:35 AM
salmeronjs85's Avatar
Default help how to weld diff on b16 tranny
any one know how or link thankls
Old Feb 8, 2008 | 12:37 PM
gibsanez's Avatar
Default Re: help how to weld diff on b16 tranny (salmeronjs85)
BAHAHAHAHA
Old Feb 8, 2008 | 02:41 PM
DAneronimo's Avatar
yeah, dont do it
Old Feb 8, 2008 | 06:26 PM
tnez's Avatar
Default Re: help how to weld diff on b16 tranny (gibsanez)
gibsanez doesnt know what hes talking about... haha, jk.
but seriously, dont fu*k up your tranny.
Old Feb 8, 2008 | 08:47 PM
Default Re: help how to weld diff on b16 tranny (tnez)
why is that not good explain
Old Feb 9, 2008 | 02:46 AM
slowcivic2k's Avatar
Unless its a drag car, you wont make turns very well, and that stresses the already weak diff side gears and pinion gears. The outside wheel will skip, and stress the weld/gears, so you'll have to burnout to turn, which isn't a problem for some people.... That in itself stresses the diff.
They don't last, you will end up replacing it in short order, if not the whole thing if it explodes and ruins the case.
Poor welds make it happen even faster. Anyway you look at it, prepare for another differential, hopefully of decent quality, if not a different transmission.
Weld the side gears to the pinion gears, take lots of pictures, before it blows up, and after, and post them on here.
Old Feb 9, 2008 | 03:32 AM
johnlear's Avatar
Banned
Default Re: help how to weld diff on b16 tranny (slowcivic2k)
Locked differentials are a complete pain to live with. Years ago I owned a little sports car (like a Lotus Super 7) and stupidly (at least ignorantly) decided to weld the differential up (live rear axle). This made the car a demon accelerating from a standing start (two black lines in 1st gear and a good 'chirp' into 2nd gear, the car rocketing away like a very startled cat), but that was the only good thing about it.
At slower speeds the locked rear end literally pushed the front and it understeered badly, even at walking speed (accompanied by uncomfortable jerking as the four tyres all fought against each for longitudinal and lateral traction). Really chuck it into corners and it would steer neutrally if you power slid it, but get it even a little bit wrong at higher speeds and it would snap into vicious oversteer with no warning (spun it more than once).
To say the locked differential made the handling unforgiving would be an understatement (and in the wet it was truly trecherous, a handful even at quite sensible speeds). Having said that, if you drove it like a maniac (in the dry) the handling was really very good, but you had to be really on your toes to catch oversteery moments. At any speeds below 'maniacal' the car was horrible, certainly not a suitable street set up, and it was a great relief when I fitted a proper differential.
I know this was with a RWD car, but I'm sure a FWD would be equally (nearly?) as unpleasant with a locked differential, maybe with understeer being even worse and all / most of the time(?).
PS Just remembered, one day I broke a half shaft (probably due to all the stress and strain created by the locked diff), but the neat thing was that I could still drive it home! You'd be amazed at the weird things a car does with drive to only one rear wheel...
Old Feb 9, 2008 | 05:58 AM
gibsanez's Avatar
Default Re: help how to weld diff on b16 tranny (johnlear)
A completely locked diff in a FWD car would be terrible to drive, and I would imagine worse than a locked RWD car, simply because the front wheels are the ones you steer with. I couldn't even imagine being able to drive the thing in a full parking lot.
This has to be the worst idea I've heard in years
Old Feb 12, 2008 | 12:43 PM
tnez's Avatar
yeah, bad idea... everytime you turn, one of the wheels will be breaking traction (screachin'), haha. just do what slowcivic2k said, do it, take lots of before and after pictures, then post em up on here... Im sure you will see why LIMITED-slip differentials work better than NON-slip differentials.
Old Feb 12, 2008 | 04:15 PM
96 GSR-T's Avatar
thanks god you live in TX and not around here.
Old Feb 12, 2008 | 08:20 PM
johnlear's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">A completely locked diff in a FWD car would be terrible to drive, and I would imagine worse than a locked RWD car, simply because the front wheels are the ones you steer with. I couldn't even imagine being able to drive the thing in a full parking lot.
This has to be the worst idea I've heard in years</TD></TR></TABLE>
At walking speeds my little sports car with the locked diff made ridiculous loud howling tyre noises on smooth concrete. I'm sure it could be heard from one end of an enclosed parking lot to the other.
Old Feb 13, 2008 | 12:29 PM
tnez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnlear &raquo;</TD></TR><TR><TD CLASS="quote">
At walking speeds my little sports car with the locked diff made ridiculous loud howling tyre noises on smooth concrete. I'm sure it could be heard from one end of an enclosed parking lot to the other. </TD></TR></TABLE>
thats exactly what i said would happen...
raiden571
Apr 29, 2009 08:39 PM
lsvtec2000
Transmission & Drivetrain
Dec 25, 2008 03:42 PM
vtecn8ive
Oct 26, 2005 04:59 AM
slimer007
Aug 14, 2005 10:59 PM
