ALL MOTOR?? SLEEVES or NO SLEEVES
okay so me and my roommate had a conversation about all motor...
to build a full all motor (lets say a full toda build up)
toda crank
toda rods
toda pistons/rings
toda valves
toda valve springs and retainers
toda high power vtec cams
toda cams
toda valve guides
toda high stopper metal head gasket
toda throttle body
toda headers
toda timing belt
for instance...my motor has darton sleeves already at 84mm, decked 2.0, head has 3 angle valve jo, pnp on intake and exhaust
im just wondering if some people do sleeves their all motor or not...would you do just in case or not???better for the long run too or not?? so if you guys and girls can help me out...it'll be great...thanks
toda crank
toda rods
toda pistons/rings
toda valves
toda cams
toda valve guides
toda throttle body
toda headers
toda timing belt
thanks....yeha alittle over doing it with the toda things...but i just wanna see a full toda's capabilities are you know...so thats why..thanks though
if you were going all out all motor why wouldnt you put sleeves in it, no one with a serious race motor runs 81mm bore, thats why people sleeve it not for the "protection" cause if you think about it and somthing happens where you break a rod the cylinder wall is expletiveed no matter what sleeve is in there, with all motor you have no boost no nitrous and the only way to gain a little of what they have is bigger cylinders, as they say there is no replacement for displacement unless you have a turbo haha but all motor hince the name does not.... SLEEVE IT.
Jake
Jake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb18c5 »</TD></TR><TR><TD CLASS="quote">dont think twice about it, sleeve it
for an all out build i'd say to sleeve it for sure. but the B20Vtec stock sleeve with the RS / Sparks pistons make some really good power. and they are already 84 bore.
</TD></TR></TABLE>for an all out build i'd say to sleeve it for sure. but the B20Vtec stock sleeve with the RS / Sparks pistons make some really good power. and they are already 84 bore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hrs-parker »</TD></TR><TR><TD CLASS="quote">okay so me and my roommate had a conversation about all motor...
toda crank
toda rods
toda pistons/rings
toda valves
toda cams
toda valve guides
toda throttle body
toda headers
toda timing belt
im just wondering if some people do sleeves their all motor or not...would you do just in case or not???better for the long run too or not?? so if you guys and girls can help me out...it'll be great...thanks </TD></TR></TABLE>
Sleeve it and don't forget to get tha mad Ill toda power seat belt covers yO!!!!
toda crank
toda rods
toda pistons/rings
toda valves
toda cams
toda valve guides
toda throttle body
toda headers
toda timing belt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 »</TD></TR><TR><TD CLASS="quote">This is a joke, right?
Does Toda even make all those products?</TD></TR></TABLE>
yes, toda does make all those parts, but he did list cams twice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 »</TD></TR><TR><TD CLASS="quote">Whatever the case, all those parts would cost a ridiculous amount for (probably) a gain that will not justify the cost.</TD></TR></TABLE>
he's just buying expensive version of the parts most people upgrade anyway, stroker kit, cams, headgasket, itb's, header etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
yes, toda does make all those parts, but he did list cams twice.</TD></TR></TABLE>
lol u forgot to realize.. the toda high power cams are used when in vtec.. so for pre vtec u need the toda cams..
lol!!
true, people sleeve most of the time for the fact that the bigger bore is too much for stock sleeves in most n/a cases,
def this build when done.. will just be as strong as ur typical 2.0 with skunk2's , or other brands..
but def makes the line-up/rollcall list of mods look sweet "TODArized" ahaha
lol!!true, people sleeve most of the time for the fact that the bigger bore is too much for stock sleeves in most n/a cases,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">he's just buying expensive version of the parts most people upgrade anyway, stroker kit, cams, headgasket, itb's, header etc... </TD></TR></TABLE>
Exactly, that's what I meant. He can get the same for less.
sorry, i meant toda camshafts and cam gears...
i know that toda is more of the expensive stuff to get...but...weksos gave me a deal on parts...valves,valve guides,dual valves and retainers only for 650..shipped
toda specs c's are only 850 shipped...i think the head is only gonna be toda...for that reason cuz, im not sure if they'll do the custom pistons for me so ill probably go with the 84mm 13.1 comp. wiesco pistons...eagle rods...the other options was that...but thanks guys for the input on the sleeves...me and my roommate we talkin about this coming back from Chicago...thats why...i figured on the safe side...sleeves would do the work...thanks...
Blanket Jackson
30
Sep 29, 2004 11:12 AM
hybridsedan
May 23, 2003 04:29 AM
93B18
Jun 20, 2001 11:00 AM
