Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spec Stage 2+ clutch- unusually stiff pedal feel?
Old Feb 8, 2008 | 01:28 AM
silverskateEF9's Avatar
Default Spec Stage 2+ clutch- unusually stiff pedal feel?
I bought a Stage 2+ Spec clutch and had it installed, and the clutch pedal is STIFF! Even more so than my old Proactive clutch I had no idea it would be that hard. Will it break in and soften up some, or will it always be like this?
Old Feb 9, 2008 | 06:19 AM
turboteener's Avatar
Banned
Default Re: Spec Stage 2+ clutch- unusually stiff pedal feel? (silverskateEF9)
Mine was actually lighter than the factory pedal. Something isn't right. You need to first check all you pedal and cable linkage parts. Check the routing on the cable and make sure it doesn't have a bunch of tight bends in it. One of my customers cars had the clutch cable clamped pretty tight to the fuel rail and other parts and it was constricting the cable.
Old Feb 9, 2008 | 10:12 AM
Xian's Avatar
My Spec clutch (stage 3?) has a really light pedal feel. Sounds like something isn't "right".
Old Feb 15, 2008 | 01:39 AM
Default Re: Spec Stage 2+ clutch- unusually stiff pedal feel? (Xian)
I've asked the shop about the cable tension, they checked it and say it doesn't make a difference. Then it hit me- esp. after reading people's responses that their experience with the Spec clutch is that it feels about the same as stock- would having a cable-actuated clutch instead of a hydraulic clutch make the difference? I have the Hasport hydraulic-to-cable conversion on my Type R. Because I don't have the extra hydraulic force, could that be a factor in making the clutch pedal hard to push to the floor?
Old Feb 16, 2008 | 01:35 PM
MurrrFit!!!'s Avatar
This is JdMhEaD posting on murrrfits name.
I have a spec stage 3 unsprung disc in mine, and a competition clutch pressure plate, holding 375whp. But when i went in to Spec to get the clutch (yes they are local for me) i told them what setup that i was looking to run. They tried to convince me to run their pressure plate, which is very very stiff i have heard from others, as my pressure plate is 1800lbs of pressure (measured by them) and they said that their plates are arond the 2800-3200lb pressure.
Maybe you got a similar pressure plate to what they were trying to sell me.
Coolcat55
10
Jan 5, 2013 12:42 AM
rdwaldo
Oct 11, 2006 01:20 PM
See Are X
Apr 25, 2002 05:04 PM
