91 Crx B16 Help
Old Feb 7, 2008 | 06:19 PM
JDM Micheal's Avatar
Default 91 Crx B16 Help
I was driving my car and it just cut off on me. The Alt. and Bat are good but when I put my key in the ignition I have no power. I've heard all kinds of bullcrap reasons to what the problem could be..
Old Feb 7, 2008 | 09:32 PM
acmoc's Avatar
Default Re: 91 Crx B16 Help (JDM Micheal)
I had this once, for me it was one of the fuses, one in the engine bay. forget which one, but my mechanic friend hooked up his diagnostic computer to it and replaced some electrical thing in the engine bay. ?
Old Feb 7, 2008 | 11:01 PM
x4thGenCafe's Avatar
OF THE KINGS
Is your battery cables just getting loose every now and then
that happened to me before a few times and almost **** myself when it happened on the highway at night
Old Feb 8, 2008 | 03:10 AM
alscrx's Avatar
Default Re: (x4thGenCafe)
Check your ignition fuse under the hood. Its a 50amp fusible link held in with 2 screws. That controls your ignition power....
Then check your grounds...battery to tranny ground,thermostat housing, etc.
Let me know and we can go from there
Old Feb 8, 2008 | 04:21 PM
acmoc's Avatar
It's called the main relay I think, next to your passenger headlight
Old Feb 9, 2008 | 06:53 AM
soulfly's Avatar
Default Re: 91 Crx B16 Help (acmoc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acmoc &raquo;</TD></TR><TR><TD CLASS="quote">It's called the main relay I think, next to your passenger headlight</TD></TR></TABLE>main relay is also known as fuel relay, which is located under the dashboard on the driver side
Old Feb 9, 2008 | 07:07 AM
wood 1's Avatar
Try fuse 14 under the dash, it provides power to the alternator.
sxysweed
Feb 6, 2016 07:14 PM
VTECengaged
Apr 26, 2009 01:52 PM
tuto87
Mar 2, 2009 11:01 AM
Stars
Nov 25, 2005 05:36 PM
V8SHME8
24
Oct 25, 2004 04:04 AM
