LS Vtec/B20 Vtec OR GSR w/ all Type R Guts ??
Old Feb 7, 2008 | 05:42 PM
JDM_VtecTeg's Avatar
Default LS Vtec/B20 Vtec OR GSR w/ all Type R Guts ??
Just got a new 94 4 door Integra LS w/80k
not feeling the Non-Vtec thang .. looking to do a nice swap
either an LS Vtec /or B20 Vtec but i know tha bad about that
or just get a GSR Motor With all Type R Internals with a 99 - 01 LSD type R Transmission ..
let me hear some opinions..
did my research on both.
Old Feb 7, 2008 | 05:46 PM
Rickdrizzle's Avatar
gsr head, tranny w/ p30 pistons and you're good to go.
don't forget the other hardwares needed to do a reliable lsvtec build though.
Old Feb 7, 2008 | 05:59 PM
Default Re: (Rickdrizzle)
yeah thaught about it. i dont know . my last experience with a LS Vtec it blew around 4,000 miles .. due to the external oil line .. with Ctr Pistons with LS Rods
Old Feb 7, 2008 | 06:00 PM
was it with a gsr head? did you use arp rod bolts? did you use a gsr waterpump? was it atleast tuned? etc etc.
Old Feb 7, 2008 | 06:14 PM
95 B18C Head
95 B18C ECU
ARP everything .
GSR Water Pump with a GSR Timing Belt
Stainless steel oil line
Chipped & Tuned up while drive
The Real way its suppose to be.
used a LS Harness and ran the 2 extra wires [ green & white ] for the vtec .
and still dont know where i went wrong .
Old Feb 7, 2008 | 06:37 PM
96integralsvtec's Avatar
Default Re: (JDM_VtecTeg)
got any pics of the new whip?
Old Feb 7, 2008 | 06:48 PM
Default Re: (96integralsvtec)
not yet . will soon . you runnin LS Vtec on your tegg ? hows it runnin?
Old Feb 7, 2008 | 07:21 PM
it runs strong i need to get it tuned tho.looking into s100 hondata with a obd1 ecu.it has a lot of power not even tuned.so we will see when it is im from boston too so when you need a tune go over to trick engineering my boys go there an they do good work ima bring mine there soon.
Modified by 96integralsvtec at 8:57 PM 2/7/2008
Old Feb 7, 2008 | 08:01 PM
djxtc's Avatar
Default Re: LS Vtec/B20 Vtec OR GSR w/ all Type R Guts ?? (JDM_VtecTeg)
go b20vtec i have a b20vtec turbo with a stock bottom end putting down 320 hp to the wheels its all about dynoing i know the **** you heard about b20's weaks sleeves and bla bla bla bla but my motor is ripping proof ive had a stock bottom end for going on 3 years boosting 11 psi daily driver hit me back if you want more info
just remember an ls vtec or full type r will never have the torq or power of a b20
peace
Old Feb 10, 2008 | 03:58 PM
Default Re: LS Vtec/B20 Vtec OR GSR w/ all Type R Guts ?? (djxtc)
still no pics?
Old Feb 14, 2008 | 10:47 AM
Default Re: LS Vtec/B20 Vtec OR GSR w/ all Type R Guts ?? (96integralsvtec)
word you from boston .
hit me up on my email for that tuning **** .
importjunkieusr@gmail.com
pics will be up soon of the 4 door .
and tha hondata your better off with tha s200 with tha rev limiter
Old Feb 14, 2008 | 12:14 PM
illstyliztic1's Avatar
i got a b20 vtec right now . i was wonderin did you boost 11psi just bare stock or did you put atleast anythin in it
Old Jul 17, 2008 | 07:08 PM
tc_gts's Avatar
im gonna b20Z stock bottom end...
b16a gead type r cams... no clearence issues?
mr.roboto
Oct 4, 2005 09:15 PM
808jdm_gsr
Apr 26, 2004 11:14 PM
Gimpo
Apr 12, 2004 09:48 PM
Short_Shifter
Mar 25, 2002 03:29 PM
