turbo ls wont start.... sometimes.. confused???
Old Feb 7, 2008 | 04:48 PM
lilintegra25's Avatar
Default turbo ls wont start.... sometimes.. confused???
confused?????? car will start fine the 1st time,,, drive it around a bit,, park it , try and restart it wont start,,, wait 15 min. wont start... wait like an hour it will start... this has been happening for a month or two... now this car is my weekend car,,, wont turn over.... compresson is 180-180-180-90. I ran low on oil and lost compression in one cylinder + blowby.... has fuel and spark..... starter is about a year old... doesnt smoke from the exhaust.... heatsoaking??? my car should be driveable even if the compression is low..... im confused.... checked battery... fuel pump primes....
112k miles 98 ls-turbo
im going to do a rebuild anyways.. i just want it to be driveable for now....
almost forgot,,,, if i push it in 1st and slowly let go of the clutch it will start with no problem.. im using hondata s300
Old Feb 7, 2008 | 04:53 PM
jarvis199's Avatar
Default Re: turbo ls wont start.... sometimes.. confused??? (lilintegra25)
whats it tuned on? try crank fuel in crome (ifthats what you are using)...
Old Feb 7, 2008 | 04:57 PM
hondata300,,, o yea if i push it in 1st and slowly let go of the clutch it will catch it self and start
Old Feb 7, 2008 | 05:24 PM
97grnrs's Avatar
Default Re: (lilintegra25)
if its not cranking then your starter is prob going bad..
Old Feb 8, 2008 | 11:17 AM
roydogg's Avatar
Check the main relay under the driverside dash .
Old Feb 8, 2008 | 07:26 PM
JRSC01GS-R's Avatar
Default Re: turbo ls wont start.... sometimes.. confused??? (roydogg)
bad starter gets my vote
hamburgler
Aug 21, 2011 07:57 AM
WRTEG
Nov 23, 2004 12:05 PM
POWERINTEGRA
Nov 18, 2004 12:48 PM
