water leak inside the car
Old Feb 7, 2008 | 02:22 PM
hondapower321's Avatar
Default water leak inside the car
i have a 94 2dr integra. my car's interior is always wet and damped and im not sure where the water coming in from and it's still wet on a sunny day. im sure theres a leak somewhere in the car causing the carpet and everything wet. this also cause my inside windshield to be wet and fogged up.. what can i do? have anyone experience this? where should i check? i appreciate for the help guys
Old Feb 7, 2008 | 02:30 PM
tweee's Avatar
Default Re: water leak inside the car (hondapower321)
does it smell like coolant? is it leaking on the passenger side or the driver side?
Old Feb 7, 2008 | 02:39 PM
Default Re: water leak inside the car (tweee)
it's water bro, i can't seem to find where it's coming from
Old Feb 7, 2008 | 02:41 PM
tweee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapower321 &raquo;</TD></TR><TR><TD CLASS="quote">it's water bro, i can't seem to find where it's coming from</TD></TR></TABLE>
im a girl, bro ... hmm ... is it leaking on the driver side or passenger side?
Old Feb 7, 2008 | 02:47 PM
the whole carpet is wet from the rear to the front.
Old Feb 7, 2008 | 02:50 PM
tweee's Avatar
did you try searching ... i think there's like 3 links that pop up when you search that might help ... i was asking if it was coolant leaking because i have that problem and also drive a 94 integra ... my windows fog too
Old Feb 7, 2008 | 04:02 PM
Blahblah718293's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapower321 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 2dr integra</TD></TR></TABLE>
i should hope its an integra, seeing as how your in the integra section asking the question:
have you taken a look at your spare tire lately? i bet its in a swimming pool.
http://www.team-integra.net/se...=1021
if youve got that volume of water its almost definelty the sunroof drain tubes. if youve never stripped your interior before, nows the time to learn.
http://www.team-integra.net/se...D=546
Old Feb 11, 2008 | 12:52 PM
slowassgsr's Avatar
uhm does your car have a sun-roof thingy, if so then check your drain tubes O_o
I cant post more than 5 times a day : /
Old Feb 11, 2008 | 01:10 PM
EX PLCIT's Avatar
Default Re: water leak inside the car (Blahblah718293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweee &raquo;</TD></TR><TR><TD CLASS="quote">did you try searching ... i think there's like 3 links that pop up when you search that might help ... i was asking if it was coolant leaking because i have that problem and also drive a 94 integra ... my windows fog too </TD></TR></TABLE>
Coolant leaking on your carpet is caused by a bad heater core.
Old Feb 11, 2008 | 02:12 PM
cmorris87's Avatar
If your windows are fogging I would bet money its the heater core,doesnt always smell like coolant,got a buddy with a leak and his smells like syrup.Weird but true.
Old Feb 11, 2008 | 02:20 PM
super jdm yo's Avatar
Default Re: water leak inside the car (cmorris87)
everyone i know with a dc had water leaks. if it's coming from the back then it's probably coming from your taillight gaskets or hatch seal. but i don't know if that'll let enough water to come in and soak your carpet.
Old Feb 11, 2008 | 02:25 PM
Default Re: water leak inside the car (super jdm yo)
the heater core is super unlikely, and if it is that, youll be leaking coolant, and your heat wont work.
i gotta say every case ive seen of water in the cabin has been caused by the reasons of my above post.
my water leak was so bad before i noticed it, my spare tire was chillin in a kiddy pool, and my back seat bottoms, and half my carpet all the way up to the pedals was soaked.
OP, have you checked your spare tire well?
Old Feb 11, 2008 | 04:02 PM
red integra lsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapower321 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 2dr integra. my car's interior is always wet and damped and im not sure where the water coming in from and it's still wet on a sunny day. im sure theres a leak somewhere in the car causing the carpet and everything wet. this also cause my inside windshield to be wet and fogged up.. what can i do? have anyone experience this? where should i check? i appreciate for the help guys </TD></TR></TABLE>
Its either the tailight gasket, rear hatch seal, sun roof vent tube or seal, or in rare cases the door seals. Probably the sun roof seeing how its the front part of the carpet thats wet.
Old Feb 11, 2008 | 04:12 PM
Dogginator's Avatar
Daisy... Daisy...
For your whole carpet to be wet, you have major issues. Is water puddled in your car? Typically it will not migrate from one footwell to another or from front to rear. Crank your heat on high with the windows cracked when you drive. You need to get that dry to find the leak.
Usual suspects:
AC evaporator drain tube
Sunroof drain tubes
Hood latch cable gasket
Missing rubber grommet
Tail lights
Old Dec 19, 2009 | 11:44 PM
Hello Honda Tech's Avatar
Water is chillin' where my spare tires suppose to be, my carpet behind the driver seat is wet and also where the bacc seats are those are sitting in a mini puddle. Anyone know what i should do?
Old Dec 20, 2009 | 07:12 AM
vtec maniac's Avatar
chaaaa
Old Dec 20, 2009 | 07:54 AM
boosted.CRX's Avatar
I just went through all of this for the last year or so trying to find all of the leaks and boy I had many. A combination of things were happening to me, my rear window sprayer was leaking onto the headliner causing mold, so I sealed it with polyurethane. The seam on the rear pass side wheel well was seeping water in when I would drive on the rain because the wheels would mist the water up into it, this was also fixed with the poly. Then my tail lights, these were the biggest ****. I managed to fix one of them by making a new gasket out of hobby foam but it didn't work for the pass side. I tried sealing it with poly calking, didnt work. I ended up drilling holes all over the bottom of the tail light so the water would pass through it and not collect in the light itself. The leak was somehow so bad the tail lights would fill to the brim then come sloshing out when I drove around. This collected in the spare tire area for so long until it rusted of the spare tire mount and I heard the spare flying around in the back one day. When I would brake or go down a hill the water would come over into the back seat soaking the seat bottom like a water fall then running down into the rear floormat area. Needless to say I will never own a DC again because of this headache of a water leak that every Integra I know of has.
87supraT
Apr 5, 2009 05:57 PM
Armorzaku
Feb 21, 2009 12:27 AM
HankTrigg
Sep 13, 2008 06:25 PM
tcontesh
May 2, 2006 07:08 AM
brent_G
21
Nov 21, 2003 12:59 PM
