Suspension & Brakes Theory, alignment, spring rates....
HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING?
Old Feb 7, 2008 | 02:16 PM
supermario680's Avatar
Default HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING?
if anyone has replace their cv joints/front axles did you ever have a problem with the damper fork through bolt just Spinning?
more
https://honda-tech.com/zeropost?cmd=fshow&id=1
Old Feb 7, 2008 | 02:52 PM
Targa250R's Avatar
be professional
Default Re: HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING? (supermario680)
Huh?
It's a bolt with a nut on the end. If the nut is missing, of course it will spin.
Old Feb 8, 2008 | 03:30 PM
Default Re: HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING? (Targa250R)
The nut is off and yes I know it will spin, but I need to get it OUT!!, tried hitting the other end with hammers and a mini-sledge. but no luck
Old Feb 8, 2008 | 03:45 PM
doubleshotz's Avatar
Use air tools if you have access to them. Saves hella time.
If not, soak it with some PB blaster overnight.
Hammer the bitch like it owe you money
Old Feb 8, 2008 | 05:40 PM
GSaura's Avatar
Default Re: HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING? (doubleshotz)
I've never had to hammer one out. Usually I can turn it with a ratchet while pushing it out with my bare hand from the other side. That seems to work pretty well. PB blaster is your friend.
Old Feb 8, 2008 | 09:13 PM
Targa250R's Avatar
be professional
Sounds like the shank of the bolt is seized to the inner sleeve of the bushing, but the sleeve has torn away from the rubber. I've seen this happen frequently in the rear but never up front, probably because that bolt is supposed to be ribbed so it doesn't make full contact with the inner sleeve.
You may just want to pay a professional to fix it. Otherwise, you're in for some torching and/or drilling if you have access to the proper equipment.
Old Feb 8, 2008 | 10:26 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">I've seen this happen frequently in the rear but never up front, probably because that bolt is supposed to be ribbed so it doesn't make full contact with the inner sleeve.
is that why its ribbed? x2 though ive seen it on the rear but NEVER on the front and ive dont alot of honda/acura axle/coilover/motorswaps...
Old Feb 9, 2008 | 12:36 AM
Worst comes to worst, take a torch to it.
Old Feb 9, 2008 | 10:07 AM
thanks for the help, have already tried PB and Air Tools, didn't even come close. we whacked that thing with a mini sledge 100 times still nothing, will try harder, or a torch, thanks.
stevevang
Mar 27, 2016 04:46 AM
supermario680
Feb 8, 2008 06:48 PM
maynards_ek
Dec 25, 2007 06:45 PM
ak_teg92
16
Apr 30, 2007 04:40 PM
Eg253
Suspension & Brakes
30
Jun 24, 2006 05:10 AM
