!!!!HELP HELP CV joint HELP HELP!!!! damper fork through-bolt just SPINS!!!!!!!!!
Old Feb 7, 2008 | 02:10 PM
supermario680's Avatar
Default !!!!HELP HELP CV joint HELP HELP!!!! damper fork through-bolt just SPINS!!!!!!!!!
currently replacing my driver side axle/cv joint. everything is all taken care of EXCEPT the damper fork through bolt on the bottom of the fork just SPINS!!!! WHAT THE F!!!!! I removed the 17mil nut on one side, but the bolt on the other side just SPINS with an extreme amount of force.
We hitting it with a small sledge with an impact wrench on the other side, used PB blaster, tried to use a puller, could not get a good press. ANYONE EVER RAN INTO THIS BEFORE?
Old Feb 7, 2008 | 02:15 PM
Ej Girl's Avatar
Default Re: !!!!HELP HELP CV joint HELP HELP!!!! damper fork through-bolt just SPINS!!!!!!!!! (supermario680
So the bolt just spins after you took off the nut? can you see the other side of the bolt spinning to?
Old Feb 7, 2008 | 02:19 PM
z6hatchboy's Avatar
They will because its just a bolt and nut, no bolt thats welded or anything. Put a wrench on the bolt side and hold the wrench and use a impact on the nut, if you cant hold the wrench put a breaker bar or bigger wrench over to make it touch the ground so the ground can hold it.
"So the bolt just spins after you took off the nut? can you see the other side of the bolt spinning to?"
YES EXACTLY, it dosen't make ANY sense, its really difficult to spin and it just KEEPS SPINNING!!!! the head of the bolt never backs out from the fork!!! WTF! aaaaaarrrrrrruuuuuugggghhhhhhhhhhh!!!!!!!!!!!!!!!!
Old Feb 7, 2008 | 02:20 PM
Ej Girl's Avatar
did you try putting the nut on a little bit and hitting it with a hammer? it should not hurt the threads if you put the nut on a little bit.
Old Feb 7, 2008 | 02:21 PM
"They will because its just a bolt and nut, no bolt thats welded or anything. Put a wrench on the bolt side and hold the wrench and use a impact on the nut, if you cant hold the wrench put a breaker bar or bigger wrench over to make it touch the ground so the ground can hold it."
I have the Nut off, its just the bolt that won't come off. but you may have given me an idea
Old Feb 7, 2008 | 02:22 PM
z6hatchboy's Avatar
Also, after nuts off, you can preload the suspension with a jack to make it a lot easier and use a center punch the the bolt to knock it out, or just knock it out with a hammer.
Old Feb 7, 2008 | 02:23 PM
tried preloading the suspension, hitting it with a hammer, and mini sledge, all while using a impact wrench. and won't come out it still just spins
Old Feb 7, 2008 | 02:26 PM
Ej Girl's Avatar
well i think you going to need a new bolt and if you can get a air hammer i would get one that will get it out
z6hatchboy's Avatar
Have you tried putting a jack under the LCA or disc for the brake and preload the suspension to take the stress/load off of that bolt?
Old Feb 7, 2008 | 02:29 PM
"impact wrench" = "air hammer" didn't even get close
Old Feb 7, 2008 | 02:30 PM
yep put a jack under the disc, raised 1/2 inch, sill nothing
Old Feb 7, 2008 | 02:35 PM
z6hatchboy's Avatar
Try putting it under the fork/lca, and pushing up on it since that is where the force is coming from. I think when you put under the disc you are indirectly pushing against its force and making it worse. So try jacking from under the fork, and may the force be with you.
Old Feb 7, 2008 | 03:34 PM
instrument's Avatar
why not simply loosen the strut and drop the whole control arm with the fork attached?
Old Feb 7, 2008 | 03:43 PM
Default Re: (instrument)
"why not simply loosen the strut and drop the whole control arm with the fork attached?"
that would not be a problem except the axle needs goes throught the fork and will need to go through bottom of the fork as it is too big to slide out.
z6hatchboy's Avatar
Instrument has a point, it'd be easier.
Old Feb 8, 2008 | 03:28 PM
Default Re: (z6hatchboy)
""why not simply loosen the strut and drop the whole control arm with the fork attached?"
that would not be a problem except the axle needs goes throught the fork and will need to go through bottom of the fork as it is too big to slide out."
smmcla
Suspension & Brakes
12
Sep 17, 2024 08:07 PM
I like my R
Aug 24, 2023 08:56 PM
ADeKK
Aug 7, 2010 04:10 PM
commotion
Mar 3, 2009 07:24 PM
EM1VtecSi
Suspension & Brakes
Apr 25, 2005 02:18 PM
