Enkei RPF1 16x7 +43 or +35?
Old Feb 7, 2008 | 02:07 PM
_decker's Avatar
Default Enkei RPF1 16x7 +43 or +35?
I am looking at getting these wheels for my 2001 integra but im not sure on which offset I should get. My car is lowered on Koni/Ground Control's, right now it sits pretty low. I'd say it's a 2 3/4" drop on stock wheels on 195/55-15 tires. I don't have any major rubbing problems now, only when I am at full lock.
I want to run the +35's but im not sure if I will have clearance problems. I found a picture in the RPF1 thread of a integra with +35 offset, but it was running the wrong size tire. Im looking at running a 205/45-16 or a 215/45-16 Azenis.
Will I have any clearance problems running +35 with the above tire sizes? I don't have a problem raising the car somewhat but I don't want to get these and have the tires banging the fender and having to raise up the car like a 4x4.
Any pictures, comments or insight is welcome.
Old Feb 7, 2008 | 03:26 PM
cetcivic's Avatar
no one wants to hear the truth
Default Re: Enkei RPF1 16x7 +43 or +35? (_decker)
i like the 35s too,but,they will rub..i have 16"konig mesh 40mm offset w/ 195-50-16 tires and they rub on fast turns in the front(back is fine)..go for it tho..roll the rear fenders pull the fronts use the narrowest tire 195 or 205
Old Feb 8, 2008 | 10:30 AM
.:Made in OC:.'s Avatar
If you plan on running a wider tire then normal i would suggest going with a +35 offset. I would rather rub on the outer fender then rub on the inside fender well. You can always prevent the rubbing on the outside from rolling your fenders or just simply raising your car. Or what you can run is a +43 and throw on a 5mm spacer which brings it down to +38 and with a 215 series tire you should be fine.
Old Feb 10, 2008 | 02:49 AM
_decker's Avatar
Default Re: Enkei RPF1 16x7 +43 or +35? (.:Made in OC:.)
Anybody else?
Another question...Do you think the wheels could be machined down to another offset rather than running spacers?
Old Feb 10, 2008 | 06:55 PM
cetcivic's Avatar
not a good idea,that will probably alter the integrity of the wheel.
Old Feb 11, 2008 | 10:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _decker &raquo;</TD></TR><TR><TD CLASS="quote">Anybody else?
Another question...Do you think the wheels could be machined down to another offset rather than running spacers?</TD></TR></TABLE>
I would rather run a high quality spacer such as H&R then machining the wheel. It could possibly weaken in the integrity of the wheel.
Old Feb 11, 2008 | 11:30 AM
_decker's Avatar
I read that Enkei makes this wheel in 1 offset, then machines it down to make their other offsets. I tired getting pictures of the backside to see if it could be done but I have had no luck.
Old Feb 13, 2008 | 07:42 PM
marshun's Avatar
+35 and just cut that little lip and roll the rest a little. you'll be fine. and run 195's.
Old Feb 17, 2008 | 02:16 AM
Cuda's Avatar
well whats your reasoning for wanting to run the 35 offset..??
mynameizstitch
Apr 20, 2011 11:09 PM
rocko5845
Jan 19, 2010 11:02 AM
vtec-adykt
Jan 12, 2009 09:25 PM
slammedexv
Dec 16, 2008 05:14 AM
eluder33
Mar 7, 2005 04:01 PM
