EG6 B18 Fan Radiator pb !
Old Feb 7, 2008 | 11:12 AM
hotrider's Avatar
Default EG6 B18 Fan Radiator pb !
Hi !
I have a little problem with my EG6 swapped B18C6, my fan radiator do not work even after 100°C , 120°C ... nothing !
I've the EG6 radiator + fan !
I tested the fan via a switch behind battery and fan ... and the fan works good, i will change the termostat to, but before it, i would like to know if somebody have some infos about EG6 Radiator + B18C6
Let me know
Thanks !!!!!!
Old Feb 7, 2008 | 11:38 AM
Mashimaro's Avatar
Default Re: EG6 B18 Fan Radiator pb ! (hotrider)
double check your fuses in the engine bay (near your battery).
your stock radiator should work fine with the B18 motor. since the EG6 already came with the B16 stock, you shouldn't have any issues with the rad hoses not fitting properly.
BongoBennie
Jan 10, 2017 06:29 PM
Rafe Altschuler
14
Aug 11, 2015 04:10 PM
redboost10
Sep 9, 2006 10:37 AM
aznryd3r
Apr 27, 2006 01:45 PM
