Painting white
I have a white 95 Accord. Most of the replacement parts come with a black primer job. I was wondering if White goes well on top of black primer? Need advice from experienced painters.
If your using products from a professional auto paint system, just use a white sealer or a tint-able sealer, tinted with white toner before the base. Use a black or checkered spray-out card to ensure you have full color coverage before you clear. If your not really familiar with painting and color matching using a spray-out card will help to confirm you have full coverage and a good color match. With sealer you should have full coverage in 3-4 base coats if your color covers decently. Also make sure to use a flex agent if its available and make sure you choose the correct color variant that best matches your adjacent panels, fenders/hood.
If your using spray cans, just try to mimic these steps the best you can.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerflow »</TD></TR><TR><TD CLASS="quote"> Also make sure to use a flex agent if its available .</TD></TR></TABLE>
Why would you want to use a flex agent? Especially if its a part that is fixed like a fender and such, its a waste of material. Plus, I don't really believe in flex agents. Most flex agents will keep a part flexible for 90days...or around there, in my experience.
Why would you assume I meant parts other than bumpers?
It's very clear he is talking about replacement parts, not fixing a fender.
Bumpers are a common replaced part. Most Honda bumpers, OEM and aftermarket come in a black primed finish. I should have mentioned" if painting bumpers " or " if applicable" its pretty obvious flex agents are only meant to be used on flexible parts like bumpers. I agree that todays urethane enamel paints are very flexible and its definitely not an absolute must when using quality paint. But its still good advise.
landon.alder
42
May 26, 2010 07:51 PM
