6mm pin punch to set timing on GSR?
Old Feb 7, 2008 | 05:39 AM
Creator's Avatar
Default 6mm pin punch to set timing on GSR?
Was wondering if you need two 6 mm pin punches to set the timing on a GSR like you do with LS cams. Tool truck leaving soon I don't have time to search
Old Feb 8, 2008 | 06:35 AM
Creator's Avatar
Default Re: 6mm pin punch to set timing on GSR? (Creator)
Obviously they tool truck is long gone but I still was hoping for an answer.
What I'm refering to is the holes in the caps for the cams on the LS head. When your setting the timing with the valve cover off there are 6 mm holes that you can put a pin punch through the cap into the cam to help hold it in place when your installing the timing belt.
Does the GSR head have the same setup or is there another method for that head?
Old Feb 8, 2008 | 02:58 PM
GiT LaO'd's Avatar
When I did my timing belt for my GSR hatch, all I did when the belt was off was set the cams to the marking on the block and positioned the crank, rotated the sucker with belt on and then tightend up the tensioner. No special tool needed when I did so.
Old Feb 8, 2008 | 03:08 PM
JasonST's Avatar
Default Re: (GiT LaO'd)
Yeah just like Git LaO'd said, just make sure the cams lins up with the timing marks, and that the crank lines up with the timing marks. By the way ur sig is hilarious.
Old Feb 8, 2008 | 04:19 PM
Dazed and Confused's Avatar
I tried using the pins before and it actually makes it harder. I couldn't get the belt on for ****. Then I took the pins out and went on like cake.
LS AzZkIkr
Mar 6, 2008 06:38 AM
boomersz
Apr 5, 2007 11:14 PM
boomersz
Apr 5, 2007 09:33 PM
efyou
Jul 1, 2006 10:07 AM
99EletronblueSI
Nov 2, 2004 06:45 PM
