Cat heat up light
Old Feb 7, 2008 | 01:20 AM
ccibai's Avatar
Default Cat heat up light
hi guys,
i hv a jdm 96 spec dc2r and the catalytic converter heat up light (beside the check engine light) is on all the time, anyone can shed some light on the problem and also any ways of fixing it?
cheers
Old Feb 7, 2008 | 07:31 AM
walker111's Avatar
Default Re: Cat heat up light (ccibai)
Our cars dont have that light.
Old Feb 7, 2008 | 08:29 AM
Mugen Mike's Avatar
Replace the sensor?
Old Feb 7, 2008 | 12:34 PM
typer_696's Avatar
Default Re: Cat heat up light (Mugen Mike)
I dont know about JDM.
Old Feb 7, 2008 | 12:54 PM
LAO's Avatar
LAO
Banned
sorry we are all americanized here....we dont have the little luxuries that the real type r's have
Old Feb 7, 2008 | 04:18 PM
AltimaXX's Avatar
I was wrong. See below
Old Feb 7, 2008 | 04:21 PM
TrustAutoPerformance's Avatar
Default Re: (AltimaXX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AltimaXX &raquo;</TD></TR><TR><TD CLASS="quote">Solution A) Pull the bulb.
Solution B) I'm guessing that it means that the heating elements inside of the oxygen sensor have failed. 02 sensors have this heating element to help them get up to proper operating temperature quickly in cold weather. A new 02 sensor should fix it. However, the heating element being out is only really going to affect the first few minutes of driving when it's cold out, so if you do just pull the bulb and not worry about it, it won't be a big deal. You could also check the wires going to the 02 sensor/sensors. There should be 4 wires, one is the ground, one is the signal wire, and two will be for the heating element. Whichever two are the same color are the heater wires.</TD></TR></TABLE>
I don't think the JDM cat has a O2 sensor in it. I believe it is a temperature sensor.
Old Feb 7, 2008 | 04:23 PM
Henryx33's Avatar
Default Re: Cat heat up light (typer_696)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_696 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know about JDM. </TD></TR></TABLE>
Don't Lie
Your car has more JDM then anything else.
BlueR's Avatar
Default Re: (TrustAutoPerformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrustAutoPerformance &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think the JDM cat has a O2 sensor in it. I believe it is a temperature sensor.</TD></TR></TABLE>
Old Feb 8, 2008 | 07:44 AM
ccibai's Avatar
Default Re: (BlueR)
thanks for the reply guys, so i guess it won't affect anything right, then i will jus leave it till i find a solution to it. cheers
Bango_Vang01
Jan 19, 2010 03:02 PM
xivsavagevix
Feb 5, 2007 07:17 PM
vtecDadC2
Nov 17, 2006 09:35 AM
ibme_uk
Dec 22, 2004 03:27 AM
samvtecaccordsport
Apr 23, 2004 03:13 PM
