FS: b16, b18 short blocks, GM 3bar, DSM 450s, walbro, misc
Old Feb 7, 2008 | 12:23 AM
VRD^don's Avatar
Default FS: b16, b18 short blocks, misc.
00 B16A2 bare block with crank and mains. block had roughly 57k when taken apart, was previously boosted. nothings wrong. $100
94 B18A bare block with crank and mains. unknown miles. crank, mains cylinder walls all look to be in great condition. $150
98 b18B bare block with crank and mains, oil pump. block has been filled with devcon and fully cured. block had 20k on with it bend a rod. crank was polished/balanced by benson. $250
1997 D16y7 tranny. trans had 75k on it when pulled. trans shifts very smooth, no grinds. does not pop out of gear. $100
1998 d16y8 automatic trans. trans had 71k on with when pulled for a manual bseries swap. trans shifts smoothly. $80
d series starter. $15
SSAC bseires turbo manifold. its been flanged for a t3 or t4 hotside. 38mm wastegate flange. no cracks. $45
dseries accel 8mm spark plug wires, yellow in color. used for 200miles. $45
accel 300+ multi strike ignition. used for 2000miles before removed. needs a new coil. comes with cap, ignition box, accel 8mm plug wires, instructions. can be used on 94+integra LS, GSR, 92+ civics. $150
brand new type R timing belt. $45
brand new Type R water pump. $45
walbro 255 HP fuel pump with sock filter. only used on start up. 75
walbro 255 HP fuel pump without sock fileter. used for 1500miles before motor dropped a valve. $65
bseries exhuast flange, mild steel. $50
Brand new OMNI POWER 4 bar map sensor, uses stock honda location, looks just like OEM honda map but 4 bar- TRADE FOR AEM 5 BAR MAP..
GM 3 bar map sensor with pig tail. $65
96 integra SE wheels/sunflowers. needs new tires, tires are shot, wheels are painted gunmetal. the wheels are in flawless condition, paint is chipping off due to sitting in garage for ages, other wise they have no deep scratches or curbing at all.... 200 pick up!!
Stock 94 integra rear axle back muffler.. shoot an offer..
OEM 98 civic rear trailing arms, drums, most of the springs and clips in the drums are gone but the trailing arms themselves are good. shoot an offer
98 integra GSR power steering rack, and rear sub frame, great condition. a must when doing k swap in ek's.. shoot an offer
front civic ex knuckles with with calipers/rotors. shoot an offer.
96+ SIR civic rear bumper from passwordjdm new, with no moldings. 250 pick up
big items are pick up only. small items are shipped at buyers expense. make offer if you dont like the prices. LOCATED IN STEVENS POINT WI.
Old Feb 7, 2008 | 04:59 AM
6pucker's Avatar
Default Re: FS: b16, b18 short blocks, misc. (VRD^don)
pm'd
Old Feb 7, 2008 | 02:00 PM
VRD^don's Avatar
Old Feb 7, 2008 | 08:24 PM
VRD^don's Avatar
pm replied!
Old Feb 9, 2008 | 11:28 PM
VRD^don's Avatar
Old Feb 10, 2008 | 02:32 PM
VRD^don's Avatar
bump!
Old Feb 12, 2008 | 05:50 PM
BEEYOND's Avatar
did you get my pm.. if so call me asap.. 414 365 8521 regarding the 450cc
Old Feb 22, 2008 | 01:27 PM
VRD^don's Avatar
Default Re: FS: b16, b18 short blocks, misc. (BEEYOND)
Old Feb 22, 2008 | 06:22 PM
ja20_eg's Avatar
pm u
Old Mar 24, 2008 | 12:08 AM
VRD^don's Avatar
Default Re: FS: b16, b18 short blocks, misc. (ja20_eg)
damn.. been a while..updated prices!
Old Apr 24, 2008 | 09:41 PM
VRD^don's Avatar
new prices!
Old Apr 25, 2008 | 07:33 PM
VRD^don's Avatar
bump!
Old Apr 25, 2008 | 07:35 PM
VRD^don's Avatar
Old Apr 26, 2008 | 10:55 AM
VRD^don's Avatar
Old Apr 26, 2008 | 02:17 PM
VRD^don's Avatar
Old Apr 28, 2008 | 07:42 PM
VRD^don's Avatar
Old May 7, 2008 | 09:40 AM
Gre-EJ8-n's Avatar
Bump. Bought the injectors and just waiting.
Old May 7, 2008 | 11:26 AM
VRD^don's Avatar
Default Re: FS: b16, b18 short blocks, misc. (Gre-EJ8-n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gre-EJ8-n &raquo;</TD></TR><TR><TD CLASS="quote">Bump. Bought the injectors and just waiting.</TD></TR></TABLE>
just shipped it.. you should be getting it soon
Old May 9, 2008 | 11:25 AM
VRD^don's Avatar
bump..new stuff added and updated.
Old May 9, 2008 | 08:26 PM
VRD^don's Avatar
Old May 10, 2008 | 10:59 AM
VRD^don's Avatar
bump
Old May 10, 2008 | 05:58 PM
VRD^don's Avatar
a.dsfasdfas.dfa.sfksdfjsadfkasdf
Old May 14, 2008 | 07:20 PM
VRD^don's Avatar
Old May 14, 2008 | 09:29 PM
CBR_15's Avatar
pmd
Old May 28, 2008 | 12:43 PM
VRD^don's Avatar
