car wont start
it drove fine all day, i came home ate went to leave again, and the car wont start, it cranks but it wont turn over. can some one please help me. its an 1994 rs btw.
the fuel pump is working, so idk what it is, a friend said it could be the icm, but idk what that is.
any help would be nice k thanks.
take off the distributor, and take out your ignition coil and ignition module
take them to your local autozone and have them tested
coil based on resistance, so you need the primary and secondary tolerable ranges...if it tests out of these specs, the coil is shot
the module needs a specific machine to test....and needs to be tested 5-6 times consecutively to heat it up, as failure normally occurs when hot unless it is completely shot
thank you sir, now if its not that then i think i has something to do with my injectors not givin fuel ill keep everyone update and thank you.
