Axle/suspension Suggestions
Old Feb 6, 2008 | 10:14 PM
xxphunkxx's Avatar
Default Axle/suspension Suggestions
I broke my stock axles and I'm looking for something a little more powerful, stronger I don't know much about the axles or who makes them or even if theres a company that does for preludes but, if anyone has this info that'd be great.
I have a 98 prelude h22a4 and we have it running about 8 pounds of boost all crower internals, when we're done building it, I'm gonna take a stab and say 300-320 hp, I need axles thats can stand up. Lemme know guys...Also
if anyone can help me build a cheap suspension setup to give me some real good traction on my front tires, I got about a grand to kick. Thanks
Old Feb 6, 2008 | 11:07 PM
Hawkze_2.3's Avatar
Default Re: Axle/suspension Suggestions (xxphunkxx)
Stock axles will be fine if you learn how to launch better.
To reduce wheel hop, you can get stiffer mounts (inserts is all that's available for 5th gens right now), a tractions bar setup, and/or and engine tq damper.
The best thing for traction is going to be tires. Get stickier tires and/or drop the pressure, also an LSD will a good bit. You can also stiffen up the car to keep the weight closer to the front on accleration.
Old Feb 7, 2008 | 12:46 AM
xxphunkxx's Avatar
Default Re: Axle/suspension Suggestions (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">a tractions bar setup, and/or and engine tq damper.</TD></TR></TABLE>
Where could I find something like this?
Old Feb 8, 2008 | 11:09 AM
gstrudler's Avatar
I believe Ingalls makes a tq damper called the "Stiffy" for 5th gens...
Old Feb 8, 2008 | 11:19 AM
geramy's Avatar
explicit speed makes a 5th gen traction bar
H2BSTUPID
Feb 18, 2009 03:21 AM
importdude2000
Dec 20, 2006 12:05 PM
gsr-2nr
Dec 20, 2006 09:23 AM
92gsrteg
Apr 13, 2006 05:48 PM
Btothe3rdDegree
Apr 9, 2004 09:18 AM
