Dont know if any one has tryed this??
Old Feb 6, 2008 | 06:45 PM
Coupe DeJoe's Avatar
Default got a big dent?
I saw on you tube this guy take a dent out with a hair dryer and a can of key board cleaner the title is "Car Dent Removal with Hair Dryer and Compressed Air." Check it out. I have never seen it done so its new to me
Old Feb 6, 2008 | 06:53 PM
pdotjones's Avatar
Default Re: got a big dent? (joeywads)
there is discussion on this forum about dent removal using dry ice, the dryer & compressed air method, and all sorts of stuff.....
Old Feb 6, 2008 | 06:57 PM
new to the site (as you can see), but thanx. I'll have to check them out. i just came across on the vid and wanted to share
Old Feb 6, 2008 | 07:37 PM
Diet coke boii's Avatar
Default Re: (joeywads)
Yes I can say i've done it and it works
I had a thread about a month ago on it.
Old Feb 7, 2008 | 05:00 AM
jrmtegra's Avatar
Default Re: (Diet coke boii)
if you think about it as metal having molecules, i think i spelt that right, anyways, when you heat metal, it expands, when you make it cold it shrinks. when you heat it then cool it off really fast, it usually makes the metal "pop" back into place. a lot of times when you have a really bad dent in a car, one that needs bondo, guys will take a tourch to it then throw a wet rag on it to shrink it. same principle. just depends on how big the dent is
Old Feb 7, 2008 | 07:53 AM
swappedcx's Avatar
Default Re: (jrmtegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrmtegra &raquo;</TD></TR><TR><TD CLASS="quote">a lot of times when you have a really bad dent in a car, one that needs bondo, guys will take a tourch to it then throw a wet rag on it to shrink it. same principle. just depends on how big the dent is</TD></TR></TABLE>
That method makes the metal "shrink", its a fix to metal that oil cans after being beat back into shape.
Old Feb 7, 2008 | 12:33 PM
zdizzle's Avatar
dry ice only wrks on small dents it cause the metal to expand/contract really fast, ive heard ib bigger dents it just causes more headaches
Old Feb 7, 2008 | 01:28 PM
kelviiv's Avatar
what do you guys think about doing this on small door dings that you can only see from certain angles? think they will go away?
Old Feb 9, 2008 | 12:08 AM
dagle's Avatar
Default Re: (kelviiv)
yeah is there a way to mess up and make it worse?
drumminforev
Jul 24, 2006 10:59 PM
FD3S
Feb 20, 2006 11:38 PM
Skeletor
30
May 7, 2003 09:29 PM
oryanh
Jun 29, 2002 09:56 AM
