Starter/Battery short
So sometimes my car will take a few seconds to start. But it has not started sometimes and so I replace the battery, then I replaced my starter and it does not start so I jump it and it works. THEN I push start it, and it works all day then the next morning I have to push start it again. Has anyone had a short in their car do this?
mine did the exact same thing... every morning would take a few minutes to start and then once started it would start right up the rest the day... replaced my coolent temp sensor and it started up a whole lot easier...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yarara0825 »</TD></TR><TR><TD CLASS="quote">check your spark plug / wires and distibutor </TD></TR></TABLE>
um no are you serious?
more than likely you have some sort of parasytic drain which is drawing on the battery while the car is off....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yarara0825 »</TD></TR><TR><TD CLASS="quote">check your spark plug / wires and distibutor </TD></TR></TABLE> wow. i bet you have an accessory shorted out somewhere. like a light that circuits itself or something. oh, and by the way its distributor.
them8te
Mar 20, 2003 10:09 AM
