Power Windows in EM1
Today I notice my windows would not roll up all the way. So pulled panals off and such. I see it was on track and looked around more to find that the gear sector is all stripped?
After searching for parts. I have not seen one Power Window Replacement Kit. I thought I would everything since my motor was pretty weak even on the passenger side.. Does anyone know any store that sells regulators, rails, motor, and gear sector, pretty much everything inside to make the power window works in a kit instead of peice by peice?
Any help would be apprecaited
Thanks.
Thanks.
Go to honda and order a window regulator and motor and you will be set, Make sure when you replace them clean out the window run channel with soap and water
or just look for a window regulator not a replacement kit all you need is the regulator
itll run you about two hundred for both motor and regulator rails at honda but im sure you can find em cheaper anywhere else..
wizarddrummer
Sep 4, 2012 10:44 AM
Dub C
Oct 8, 2010 05:49 PM
