Power Windows in EM1
Old 02-06-2008, 04:59 PM
NOman0608's Avatar
Default Power Windows in EM1
Today I notice my windows would not roll up all the way. So pulled panals off and such. I see it was on track and looked around more to find that the gear sector is all stripped?
After searching for parts. I have not seen one Power Window Replacement Kit. I thought I would everything since my motor was pretty weak even on the passenger side.. Does anyone know any store that sells regulators, rails, motor, and gear sector, pretty much everything inside to make the power window works in a kit instead of peice by peice?
Any help would be apprecaited
Thanks.
Old 02-07-2008, 04:40 AM
HRD PKR
B16B_coupe's Avatar
Default Re: Power Windows in EM1 (NOman0608)
Go to honda and order a window regulator and motor and you will be set, Make sure when you replace them clean out the window run channel with soap and water
Old 02-07-2008, 05:21 AM
ej1serge's Avatar
or just look for a window regulator not a replacement kit all you need is the regulator itll run you about two hundred for both motor and regulator rails at honda but im sure you can find em cheaper anywhere else..
wizarddrummer
09-04-2012 10:44 AM
Dub C
10-08-2010 05:49 PM
dexterX51
04-06-2005 05:35 PM
professorman
11-17-2004 10:54 AM
Gennady
06-18-2002 05:23 PM
Quick Reply: Power Windows in EM1
