EF DOHC ZC problems
just installed a DOHC ZC in my 89 EF and it wont start... it just shoots flames out of the intake and exhaust manifold..WHATS MY PROBLEM????
Modified by trevino04 at 10:47 AM 2/7/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trevino04 »</TD></TR><TR><TD CLASS="quote">it just shoots flames out of the intake and headers..WHATS MY PROBLEM????</TD></TR></TABLE>
oh my god.
do you know what en engine is?
cause you sound like you should be doin no ZC swaps.
oh my god.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trevino04 »</TD></TR><TR><TD CLASS="quote">sry i miss spoke...since you seem to know something... whats the problem im having???</TD></TR></TABLE>
Have you even read any of the posts above?
Sound like baaaaad timing issue to me, but jlicrx might be onto something with improperly placed spark plug wires as well.
You also gave us NO info. As in: what kind of car did this go into (trim level, etc.), did you do the correct wiring changes? What ECU are you using? Any CELs?
set your number 1 piston at tdc, and pin the cams in place then install the belt...always works for me
theres a hole in the first cam cap...line it up w/ the holes in the cams and put a 5.5mm straight punch or allen key in each one then throw the belt on and make sure its tight
ef civic head
12
Jul 23, 2003 07:22 PM
