need a hondata s300 f22A1 stock base map
Just use a P75 file and scale the injectors. It should get you close enough. Otherwise I think you'll be hard pressed to find a stock F22 file.
You also might try a file with imported H23 maps. That would do it too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">Just use a P75 file and scale the injectors. It should get you close enough. Otherwise I think you'll be hard pressed to find a stock F22 file.
You also might try a file with imported H23 maps. That would do it too.</TD></TR></TABLE>
yep, then scale the main fuel until it idles at the correct afr
can i use the p74 isnt that the same as p75 because i have a stock p74 map in my smanager. also on the fuel trim it says 240 cc what should i scale it down too? thanks for helping guys let me know
you need to enter the corresponding injector size that you have. Any non-vtec map will essentially work and get the car started. You are going to be changing it all anyway.
ok yea i just looked it up its 240cc same as the ls usdm so im good there but you tihink i can drive around normal with that p74 map?
f22a1 wtih h23 intake manifold xs engineering power pack and h22 m2f4 tranny.besides that everthing else is stock
whats the power pack consist of?
i would imagine you would be ok temporarily if you really just needed to go somewhere but i would strongly suggest not doing this for extended periods.
