turbo h22... need help
Old Feb 6, 2008 | 03:31 PM
carlosp38's Avatar
Default turbo h22... need help
im going turbo on my h22.. ive got 750 cc injectors and a t3/t4 turbo... ive got a
2 mm inlinepro headgasket...im tuning it with hondata s200.. whats the highest anout of boost i can take it to but still be safe.... please help and thanks
Old Feb 6, 2008 | 03:51 PM
dartonh22's Avatar
Default Re: turbo h22... need help (carlosp38)
i wouldn't go past ten, is it jdm or usdm motor, jdm's are .5 higher compression
Old Feb 6, 2008 | 05:00 PM
KrazzyKarl27's Avatar
Default Re: turbo h22... need help (dartonh22)
I have a JDM H22A with 11:1 comp. I plan to run 8.7psi off the wastegate (.6 bar) Is that ok with a good tune on my Hondata s300?
Old Feb 6, 2008 | 05:43 PM
carlosp38's Avatar
its a jdm h22...about 50 k miles.. bought the motor from noyan motors in v.a.
Old Feb 6, 2008 | 06:50 PM
dagle's Avatar
Default Re: (carlosp38)
whats the specs on the turbo(s) ?
Old Feb 6, 2008 | 07:37 PM
my9thtry's Avatar
Default Re: (dagle)
Ask the your tuner.
Old Feb 6, 2008 | 07:40 PM
98vtec's Avatar
moderator emeritus
no one can tell you what the safe psi is until you get on the dyno and see what hp it makes per X amount of boost. this thread is closed as there is no answer to it besides physically putting the car on the dyno and finding out.
i honestly wouldnt go over 300-350whp on the stock motor. That is with everything PROPERLY tuned and setup.
2.2lude88
Jun 22, 2007 05:03 PM
mikegeezy
Nov 17, 2006 06:14 PM
BDRphaSe2
Jan 11, 2006 04:07 AM
95accordh22a
Jun 7, 2005 07:44 PM
95accordh22a
Mar 8, 2005 07:11 PM
