Problem with my Ef zc
Old Feb 6, 2008 | 03:24 PM
zcmotor's Avatar
Default Problem with my Ef zc
ok well i got the distributor changed cuz i was getting code 8 TDC sensor. and i still need the code 7 TPS Sensor. ok well after i changed the distributor my car started throwing lot of smoke and my car wont go above 3rpm or else the motor would start shaking as if its going to die or choking what could be the problem and how could it be fixed ?
Old Feb 6, 2008 | 03:31 PM
hondasaurusrex's Avatar
Default Re: Problem with my Ef zc (zcmotor)
is it a dohc zc? if so it sounds like your cam timing is off...re-check it
Old Feb 6, 2008 | 03:41 PM
zcmotor's Avatar
no its the single cam. this problem started happening after i changed the spark plugs and wires. Also im missing 2 screws from the dist. i dont know how it dissapered.
Old Feb 6, 2008 | 03:59 PM
SIred91's Avatar
Rainman
Default Re: (zcmotor)
If it was totaly fine before you changed the dizzy, then timing is your problem.
Old Feb 6, 2008 | 04:04 PM
zcmotor's Avatar
Default Re: (SIred91)
well actually it was still the same after and before i changed the dist. but maybe it is the timing and prob also that i didn't calibrate the spark plugs so that might be causing the problem.
Old Feb 6, 2008 | 04:05 PM
any codes? did you get the firing order right?
Old Feb 6, 2008 | 04:07 PM
zcmotor's Avatar
Default Re: (hondasaurusrex)
pssst it was actually 2 codes before now it gives me like 4 codes....which are 7,9,14,16
When do i get off trial mode ?
Old Feb 6, 2008 | 09:52 PM
JDeMilee's Avatar
It might be the sparkplugs either bad one's or they need to be calibrated
Old Feb 6, 2008 | 10:19 PM
SIred91's Avatar
Rainman
Default Re: (JDeMilee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDeMilee &raquo;</TD></TR><TR><TD CLASS="quote">It might be the sparkplugs either bad one's or they need to be calibrated</TD></TR></TABLE>
HAAHHAHHHAHAHHAHHAA......um, no.
Your timing is severely fubar, or the headgasket is fubar.
rd91sib18c5r's Avatar
It could be your tps check the plug and maybe replace it.
Old Feb 11, 2008 | 05:26 PM
zcmotor's Avatar
Im going to purchase the TPS Sensor in couple of days lets see what happens. Well i turned on my car on last time and it was White Smoke coming out i might be changing the valve cover gasket and also the head gasket see if that solves the problem
P1_Variable
22
Mar 1, 2009 05:28 PM
92hatchboi
Oct 23, 2007 07:27 AM
White91EF
May 23, 2007 10:23 PM
civic46
Feb 3, 2007 03:33 AM
DEADLYACURACCY
Mar 9, 2006 04:57 PM
