best amp to power solo baric L5.
Old Feb 6, 2008 | 01:30 PM
accordinglyevil's Avatar
Default best amp to power solo baric L5.
I'm a total noob when it come to sub and amp, but i have 2 10" Solo-Baric L5. They are the 2002 model. They are rated at 450 watts (max amp power) not sure of the RMS or the ohm rating. So what kind of amp should I use to power these sub?
Old Feb 6, 2008 | 01:42 PM
Sic_DA_Nine's Avatar
i have a solo baric l5 too...
im using the alpine 450 to push it...
Old Feb 6, 2008 | 01:47 PM
are you pushing online one sub or do you have 2 like me?
Old Feb 6, 2008 | 03:23 PM
Default Re: (accordinglyevil)
one 10
Old Feb 6, 2008 | 05:46 PM
fcm's Avatar
fcm
Old Fart
Default Re: best amp to power solo baric L5. (accordinglyevil)
The Kicker S10L5 is a 450W continuous, [900W max] sub, you should be looking for a 1x1000W RMS amp, into what ohms will depend on if you have DVC 2 or 4 ohm subs, [it is important to know the impedance of the VCs.
If you get an amp with a regulated power supply then it does not matter if they are 2 or 4 ohm VCs, an amp likr the JL Audio 1000/1 makes 1000W RMS into 1.5-4 ohms, so if you have DVC 2 ohm subs or DVC 4 ohm subs you will wire them in series/parallel, wire the VCs in series and then the subs in parallel, with DVC 2 ohms you will end up with a 2 ohm load, with DVC 4 ohms you will end up with a 4 ohm load, either way the JL amp will make 1000W RMS. 94
PS, the JL Audio 1000/1 is a very good sub amp... http://mobile.jlaudio.com/prod...d=440
Old Feb 6, 2008 | 07:15 PM
fcm, the info you stated about being 450 w continuous and 900 w max is that for 1 or 2 sub. the jl audio amp u posted is a really nice amp, but kinda out of my price range i was look for one in the range of 100 to 200 price range, do you have any suggestion for an amp in my price range?
Old Feb 7, 2008 | 05:20 AM
fcm's Avatar
fcm
Old Fart
450W continuous is for one sub, with two subs that would be 900W continuous, so the need for a 1000W RMS amp, [better to be a little over-powered.
I have no idea where you are going to get a 1000W amp for $100-$200 unless it is used or some no-name POS...http://search.ebay.com/search/search...mps&category0= 94
Old Feb 7, 2008 | 04:05 PM
bspeeddemon2007's Avatar
Default Re: (fcm)
the kenwood kac 9103 or 9104 is a good amp i am running it on two of the 12in solo-barics
Old Feb 8, 2008 | 06:46 AM
thanks for all the info fcm. i guess i got to start saving up my money.
pityocamptes
Audio / Security / Video
Dec 4, 2017 03:01 AM
Fat Cash Stack
22
Apr 8, 2012 09:35 PM
m.glisson003
18
Aug 15, 2011 06:17 PM
redteg1
Apr 9, 2002 08:46 PM
woodog
Dec 17, 2001 11:08 PM
