WHICH CAR TO MODIFIY
Old Feb 6, 2008 | 12:55 PM
nate24740's Avatar
Default WHICH CAR TO MODIFIY
OK I HAVE 89 CRX AND A 2005 CIVIC 4 DOOR EX SPECIAL ADDITION WHICH ONE SHOULD I MODIFY THE CRX NEED A LOT OF WORK BUT IT IS NOT A DAILY DRIVER SO I CAN WORK ON IT AND NOT MISS WORK, WHILE THE CIVIC IS. I WOULD LOVE TO MOD BOTH BUT THE BUDGET ONLY ALLOWS ONE. SO VOTE FOR ETHER AND I WILL MOD THE MOST VOTED
Old Feb 8, 2008 | 10:04 AM
nate24740's Avatar
Default Re: WHICH CAR TO MODIFIY (nate24740)
COME ON SOME ONE VOTE FOR THESE CARS
Old Feb 8, 2008 | 12:38 PM
gibsanez's Avatar
Try typing in lower case letters without that annoying signature and maybe people will want to help make up your mind for you
Old Feb 8, 2008 | 03:06 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate24740 &raquo;</TD></TR><TR><TD CLASS="quote">OK I HAVE 89 CRX AND A 2005 CIVIC 4 DOOR EX SPECIAL ADDITION WHICH ONE SHOULD I MODIFY THE CRX NEED A LOT OF WORK BUT IT IS NOT A DAILY DRIVER SO I CAN WORK ON IT AND NOT MISS WORK, WHILE THE CIVIC IS. I WOULD LOVE TO MOD BOTH BUT THE BUDGET ONLY ALLOWS ONE. SO VOTE FOR ETHER AND I WILL MOD THE MOST VOTED
this isn't that hard to decide.. the crx... keep your daily driven Newer car stock. it will get you from point A to point B and keep you cool with AC. Crx is lighter, cheaper to work on. easier to swap a crapload of different motors into. the aftermarket support is HUGE for the crx.
so in other words. Modify The CRX!! leave the 05 civic to drive daily!
Old Feb 11, 2008 | 03:56 AM
nate24740's Avatar
Default Re: WHICH CAR TO MODIFIY (h22crxpwr)
thanks for the reply and i will take you advice
Old Feb 11, 2008 | 05:08 AM
jhammond_82's Avatar
Reject Papi
wow, one person answers and you make up your mind with that? i guess you didn't make up your mind though, h22crxpwr did. but i do agree the crx. since its not your dd.
Old Feb 11, 2008 | 04:49 PM
StorminMatt's Avatar
Default Re: WHICH CAR TO MODIFIY (jhammond_82)
One more for the CRX. As far as I know, the ONLY thing you can really do to the 2005 Civic is a K-series swap. And although this can make some SERIOUS power, it is going to be VERY costly - especially considering it will also need a mount kit. Also, because of the weight of the car, it is unlikely that even a good K-series swap is going to be able to make it as quick as, say, a B-series or H-series swap into the MUCH lighter CRX.
JollyGreen
Nov 23, 2008 10:55 AM
Stunna MIKE
Jun 2, 2006 09:24 PM
Chief Wenceslaw
Apr 27, 2006 08:57 PM
Hanmin
Apr 22, 2006 04:29 AM
paulzy
Jun 27, 2002 10:37 AM
