EACV? problems... No CELs
Old Feb 6, 2008 | 12:41 PM
crooked muffler's Avatar
Default EACV? problems... No CELs
so i swapped a d16z6 IM into my mpfi swapped b2 which was running the a6 IM... there are no CELs and no vacuum leaks.
I kept the a6 TB, caus I wanted to keep my map sensor where it was
we did the swap w/ a Hondata gasket, everything went pretty smoothly; we got rid of the dashpot because it was rubbing and causing idle problems (it was stuck at 2k); as far as I know the dashpot is just for keeping yr idle good in extreme weather and throttle blips. The EACV (or IACV) is what does yr cold start... I just hav to start it up with my foot on the throttle a bit, keep it at 2k for a few minutes and then b easy on it... but i would prefer to fix this as it is my DD.
any ideas?
I searched and the only strange loop hole is that Im throwing no CELs
Im going to check if power is coming from the sensor, if it is; then im assuming the eacv is broken.... unless any1 has better ideas or encountered this same problem.
Old Feb 6, 2008 | 05:28 PM
Default Re: EACV? problems... No CELs (crooked muffler)
NO CELs, no cold start....?
Old Feb 9, 2008 | 10:48 AM
pretty sure now its the dashpot...
StefenCruthirds
Feb 22, 2019 06:05 AM
bads2k
Feb 2, 2010 10:07 AM
kootari
Feb 10, 2007 04:07 PM
mikeunreal
Oct 27, 2005 02:39 PM
Kamin
Jan 12, 2002 08:43 AM
