FS/FT: mildly built obd2 LS-VTEC w/ p73
Old Feb 6, 2008 | 11:21 AM
dubzz24's Avatar
Default FS/FT: mildly built obd2 LS-VTEC w/ p73
14k k's (8k ish miles) on the build. Looking to trade for an OBD2 swap + cash. Preferably a stock b16a2. If not then a straight sale is fine too. The motor is still in the car and can be seen running, also if you need help with the swap we can arrange a time where I can do it for you. The motor is running a stock ITR p73 ecu, and runs great on it. Should be making in the neighborhood of 200hp.
Make an offer!
Head:
B16A2 Cylinder Head
ITR dual valve spring set
ITR retainers
Jun Type 2 cams
Skunk 2 Pro series Cam Gears
Power Enterprise Timing Belt
Golden eagle Cam plug
Golden eagle Vtec dowels
Charcoal grey powder coated Valve Cover
AEM Cold Air Intake (Flat black)
Block:
B18A2 block.
Std bore PR3 pistons
Shot peened B18a rods with ARP rod bolt inserts
ITR water pump
ITR oil pump and pick up
Golden Eagle Oil Sandwich kit for LSVtec conversion
H22A breather nipples
New B16a2 Lower Timing cover
Transmission:
LS Transmission
Skunk 2 Short Shifter
All new OEM Honda bearings and seals in transmission
ACT Street lite flywheel
eride89
Mar 10, 2011 03:42 AM
tban21
Engine Management and Tuning
Feb 15, 2010 05:13 PM
whatisJDM
Northwest (Sales)
13
Feb 17, 2008 06:49 PM
b16std
Oct 15, 2006 03:11 PM
