help turbo d15b2/y8
i got a d15b2 block with a ported & polished Y8 head in a 90 CRX . my goal is to reach to 200 to 300 HP.my BUDGET IS NOT DAT BIG BUT GOOD.
WAT BLOCK WILL BE GOOD FOR THE PORTED AND POLISHED Y8 HEAD. AND WAT TURBO SET UP I SHOULD DO.AND HOW LONG WILL IT LAST FOR DAILY DRIVING. THANK YOU
Modified by allmotor b20 crx at 2:43 PM 2/6/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">wow inglish ownz joo.</TD></TR></TABLE>
First off, 200+ whp on the stock d15b2 bottom end is asking for the impossible, especially if it has the usual 100-200k miles on it. That said, the answer to how long a 300whp d15b2/y8 combo would last - a week at best.
In most cases, a vehicle with a b2 block is an already light chassis (EF), so 150-200whp is more than enough for a fun DD. For a budget, I'd suggest a volvo/saab turbo (50trim T3 aka the ".42/.48"). At just 6psi you'd be at tuned NA B16 whp numbers, but with much more torque. At 11psi, you'd be at/beyond tuned GSR numbers.
You can make a decent kit with a turbo like that for under $1500 for everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor b20 crx »</TD></TR><TR><TD CLASS="quote">i got a d15b2 block with a ported & polished Y8 head in a 90 CRX . my goal is to reach to 200 to 300 HP.my BUDGET IS NOT DAT BIG BUT GOOD.
Modified by allmotor b20 crx at 2:43 PM 2/6/2008</TD></TR></TABLE>
Boosting minime setups are bad news. Timing problems acure when you mix match heads on d-series. Get yourself a d16z6 and call it the day!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor b20 crx »</TD></TR><TR><TD CLASS="quote">can i get a y8 block and be good for turbo.i all ready got a ported & polished y8 head.</TD></TR></TABLE>
A y8 block will be fine. Got any pics of that head?
d_EG COUPE
May 26, 2008 12:07 AM
MooreBoost
Dec 8, 2004 06:50 PM
