Wierd car starting problem. Help asap.
Old Feb 6, 2008 | 09:21 AM
b20acura's Avatar
Default Wierd car starting problem. Help asap.
have a b20b with gsr tranny. about 90k on motor.
this morning i went to start my car. forgot i left my fuel cut off switch in off position, cranked the car then realized it. turned on the fuel cut off switch and tried to start the engine, i wont crank.
why isnt it cranking?
i can only hear it click. the first time i turned the key with the fuel cut off switch off it cranked, but now it won't.
any help appreciated. thank you
Old Feb 6, 2008 | 04:10 PM
63HMOOB's Avatar
Default Re: Wierd car starting problem. Help asap. (b20acura)
you should check the easy stuff first like batt, fuses, relays, if any melt/burned wires maybe you blew a fuse cause you forget to turn your switch on. if it clicks, but doesn't crank sounds like a starter problem. you can get someone to bang on the starter solenoid while you are cranking it and see if it starts.
Old Feb 6, 2008 | 06:18 PM
b20acura's Avatar
Default Re: Wierd car starting problem. Help asap. (63HMOOB)
well i figured that i didn't blow any fuses or melt any wires. because i started it 15 mins later and it work fine. don't know what the problem is still. anyone?
Old Feb 14, 2008 | 09:12 AM
b20acura's Avatar
Old Feb 14, 2008 | 09:17 AM
AccordSleeperZzZ's Avatar
did you try by-passing the fuel cut-off switch and give it a try?
GRIFTERX
Jan 30, 2009 02:38 PM
transitions
Jan 9, 2006 10:36 AM
rodvang
23
Nov 5, 2005 05:57 PM
91blksi
Dec 13, 2004 07:29 AM
VSM3point5genDC4
Jan 20, 2004 09:55 AM
