thermostat
Old Feb 6, 2008 | 06:37 AM
aziaticvang's Avatar
Default thermostat
can i run a my car without a thermostat? need to check to see why my car is still overheating.
Old Feb 6, 2008 | 06:40 AM
pdotjones's Avatar
Default Re: thermostat (aziaticvang)
its possible, but recommended... just take it out if check to see if its operable. if not, replace it...
Old Feb 6, 2008 | 06:47 AM
Default Re: thermostat (pdotjones)
but can i drive with it off for a while? maybe like 30 mins to and hour?, because it overheats for some sort of reason that i cant seem to figure out
Old Feb 6, 2008 | 06:57 AM
pdotjones's Avatar
sure....
Old Feb 6, 2008 | 07:16 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziaticvang &raquo;</TD></TR><TR><TD CLASS="quote">but can i drive with it off for a while? maybe like 30 mins to and hour?, because it overheats for some sort of reason that i cant seem to figure out</TD></TR></TABLE>
If it's really cold where you are I would limit how long you drive it w/o a thermostat. Can't you just get a new one and swap it in when you take out the old one?
Old Feb 6, 2008 | 07:18 AM
Default Re: thermostat (mcvtec)
what im trying to figure out is why my car is overheating, ive changed my thermostat like 4 times already and i think i finally got a good one, but uhh i want to see if anything whats causing my car to overheat.
Old Feb 6, 2008 | 07:24 AM
BryanM.'s Avatar
Resident Gearhead
plugged radiator?
Old Feb 6, 2008 | 07:36 AM
pdotjones's Avatar
water pump going bad?
Old Feb 6, 2008 | 07:41 AM
HondaPartsHero's Avatar
Technical Hero
you could also have air in the system
Old Feb 6, 2008 | 09:29 AM
i have no idea if its the water pump or not because i replaced it about 4 months ago.
and i dont think it does have air in the system becuase i tried jacking the car up and everything alreay, not much more i can do. unless their is then let me know
Old Feb 6, 2008 | 09:57 AM
buzzsaw1458's Avatar
before you start troubleshooting have everything stock intact ex. thomostat
Old Feb 6, 2008 | 09:59 AM
Default Re: (buzzsaw1458)
yeah i do have everything stock intact
1baddcivicsi
Oct 25, 2006 07:03 PM
delsolb16
Sep 21, 2005 07:15 PM
JDM-EJ1
May 16, 2005 08:07 AM
Spence
Mar 21, 2005 02:19 PM
ITR Demon
Dec 20, 2004 02:57 PM
