Engine Harness Question?
Old Feb 5, 2008 | 08:27 PM
Honda_Fanatic's Avatar
Default Engine Harness Question?
What is the USDM year breakdown for engine harness changes?
I have a 2000 GSR and need a engine harness, but am not sure what year harness's will work?
Are any of the EK civic harness's adaptable? I don't mind modifying the harness a bit, I just need something that plugs into the shock tower harness's!
Thanks
Old Feb 5, 2008 | 09:26 PM
Default Re: Engine Harness Question? (Honda_Fanatic)
Old Feb 5, 2008 | 09:34 PM
St Jimmy's Avatar
* B A N N E D *
P72 : 96-99 OBD-2a Integra GSR
P72 : 00-01 OBD-2b Integra GSR
Taken from: http://www.superhonda.com/foru...22260
Im not sure what the difference bettween obd2a and obd2b but I swaped a obd2a motor into a obd2b civic and everything was plug and play, everything worked fine, so I would say any 96-01 integra harness would be the same.
Old Feb 6, 2008 | 12:59 PM
Default Re: Engine Harness Question? (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">P72 : 96-99 OBD-2a Integra GSR
Im not sure what the difference bettween obd2a and obd2b but I swaped a obd2a motor into a obd2b civic and everything was plug and play, everything worked fine, so I would say any 96-01 integra harness would be the same.</TD></TR></TABLE>
Can anyone confirm this for sure?
I really need to know ASAP!
Again I have a 2000 GSR and need an engine harness for it, what years are compatible?
Does the engine harness change from 96-01?
Are any of the 96+ Civic harness's Plug and Play? Besides of course modifying the sensor plugs and wires etc!!
Old Feb 7, 2008 | 09:53 AM
sol_1's Avatar
the 96+ civics harness goes all the way through the firewall and directly connects to the ecu. and the integra engine harness connects at the shock tower. not sure if that helps.
TwoKSiR
Dec 18, 2008 10:28 AM
civicex442
Dec 2, 2007 07:38 AM
doidera00
14
Nov 16, 2005 09:35 PM
Charlie Moua
Sep 25, 2003 04:19 AM
IN VTEC
Jul 27, 2003 08:01 AM
