5th gen exhaust making raspy noise?
Old Feb 5, 2008 | 07:44 PM
victor.m's Avatar
Default 5th gen exhaust making raspy noise?
I bought my car about a month ago, the guy mentioned that it didn't have a cat converter..So then I noticed the exhaust makes a really raspy noise, almost as if something is rattling at a very high pitch. At first I thought the pipes might be loose or something, but then someone suggested that it might be the lack of a cat converter..so I'm wondering, will a cat converter solve my problem? I need to get one anyways since running my car without one is ..well, not good.
To be a bit more descriptive, the noise is just plain down raspy. It also doesn't occur at very low acceleration, and when I surpass a certain acceleration it dissapears, and then comes back sometimes. I can record it if needed.
Also ,if a cat converther is the case, how do I go about installing then? Does it just join up somewhere along the pipes? I figure the pipes must be soldered because of the lack of cat convereter..is installing it something I can do myself?
Appreciate it guys, thanks in advance.
Modified by victor.m at 9:01 PM 2/5/2008
Modified by victor.m at 9:02 PM 2/5/2008
Old Feb 5, 2008 | 07:59 PM
gd99em1's Avatar
Default Re: 5th gen exhaust making raspy noise? (victor.m)
if your sure it is coming from the exhaust and not a bolt or the like rattling, then most likely it will solve your problems.
not having a cat usually makes all but a few exhausts sound like a buzzing bee if you punch it.
Qwikrex
32
Jul 21, 2011 05:12 AM
Voodooboy520
14
Aug 14, 2006 01:52 PM
raceboy71
Mar 26, 2005 08:25 PM
Vtecfool
Jul 1, 2003 10:32 AM
