About the thermal fan switch
Old Feb 5, 2008 | 04:49 PM
Jonny Rocket's Avatar
Default About the thermal fan switch
I have a 1990 civic dx hatch with a sohc zc swap... I had a bad radiator that leaked. I replaced my radiator after I started havin over-heating problems from my coolant leakin out real quick. After that I didnt have any problems. One night I was sittin in heavy traffic when I noticed I was over-heating. I checked it out and come to find out my fan doesnt turn on. I applied 12 volts to the fan and it worked. Problem is I cant find the thermal switch, I looked in my Haynes Manual and it shows that it is located on the radiator but I dont have one on mine. Is it somewhere else???
Old Feb 5, 2008 | 05:17 PM
Patty's Avatar
Default Re: About the thermal fan switch (Jonny Rocket)
Yeah I got fooled by that too. I still don't know exactly for D-series. But check next to your thermostat housing. If it's there it should be a round brown plastic plastic piece. I don't think thermoswitches are compatible between ef's and later models. I'm still researching . I have mine grounded to the frame and hot wired to a switch on the console real stealth-like. Now it comes on when I command!
Old Feb 5, 2008 | 05:27 PM
whiteknightef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny Rocket &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1990 civic dx hatch with a sohc zc swap... I had a bad radiator that leaked. I replaced my radiator after I started havin over-heating problems from my coolant leakin out real quick. After that I didnt have any problems. One night I was sittin in heavy traffic when I noticed I was over-heating. I checked it out and come to find out my fan doesnt turn on. I applied 12 volts to the fan and it worked. Problem is I cant find the thermal switch, I looked in my Haynes Manual and it shows that it is located on the radiator but I dont have one on mine. Is it somewhere else???</TD></TR></TABLE>
Its under the intake manifold in the back of the block, located between number 2 and number 3 cylinders. You will notice a small rubber cover over it. It has two wires and will be green and brass colored.
here is one on ebay:
http://cgi.ebay.com/ebaymotors...sting
Old Feb 5, 2008 | 05:35 PM
Default Re: About the thermal fan switch (Patty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patty &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I got fooled by that too. I still don't know exactly for D-series. But check next to your thermostat housing. If it's there it should be a round brown plastic plastic piece. I don't think thermoswitches are compatible between ef's and later models. I'm still researching . I have mine grounded to the frame and hot wired to a switch on the console real stealth-like. Now it comes on when I command!</TD></TR></TABLE>
I was thinkin about doin that too.
Old Feb 5, 2008 | 05:38 PM
Default Re: About the thermal fan switch (whiteknightef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteknightef &raquo;</TD></TR><TR><TD CLASS="quote">
http://cgi.ebay.com/ebaymotors...sting</TD></TR></TABLE>
Damn! Ight thanks man...
Old Feb 5, 2008 | 05:42 PM
Crx Jimmy's Avatar
check the relay too it could be that as well
Old Feb 5, 2008 | 05:59 PM
Default Re: About the thermal fan switch (Crx Jimmy)
where and what is the relay called??
Old Feb 5, 2008 | 06:48 PM
Crx Jimmy's Avatar
the fan relay is right behind the headlight on a bracket
Old Feb 6, 2008 | 03:32 PM
oh okay thank you
Old Feb 7, 2008 | 06:52 PM
follow the wires you should find a couple things you can check on that circuit!
crxguy406
Oct 26, 2023 09:24 AM
chellerfl
Jul 13, 2016 07:43 AM
therhett17
Aug 13, 2015 09:07 AM
tonysaur
Nov 17, 2007 11:39 AM
808MAUI
Feb 23, 2006 07:51 PM
