skunk2 IM making me lagg
Old Feb 5, 2008 | 04:32 PM
dc2_916's Avatar
Default skunk2 IM making me lagg
im having problem. my geezer is not fast like it use to be.. after i installed the manifold i can hear the IM sucking in hella air .i barely step on the gas and u hear shh shhhhhh.. wtf? and its makin my car lagg hella bad and i dont kno whats wrong. what are some advice.. help
Old Feb 5, 2008 | 04:39 PM
ls19integra95's Avatar
Default Re: skunk2 IM making me lagg (dc2_916)
kinda sounds like you may have a vacuum leak, maybe a vacuum line cracked or desconnected, or maybe intake mani gasket or throttle body gasket ripped or somethin...
Old Feb 5, 2008 | 05:09 PM
you have a cel?
Old Feb 5, 2008 | 05:42 PM
TomsDC's Avatar
LOL he meant Check Engine Light. is it on?
Old Feb 5, 2008 | 05:52 PM
Mfoehrkolb's Avatar
Default Re: skunk2 IM making me lagg (ls19integra95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">you have a cel?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_916 &raquo;</TD></TR><TR><TD CLASS="quote">nah.. hit me up on aim right now. insanemienboi</TD></TR></TABLE>
--- L O L! I know there is a couple threads about installing a Skunk2 Mani properly. You could check that out and make sure you did everything down to spec. You might have just gone and screwed up on the installation.
Old Feb 5, 2008 | 05:58 PM
tomithy's Avatar
Did you get the car tuned after putting on the IM?
Old Feb 5, 2008 | 06:47 PM
Default Re: (tomithy)
hey man, did turnin the dizzy back fix it???
Old Feb 5, 2008 | 07:23 PM
dc2_916's Avatar
Default Re: (ls19integra95)
yeah it worked but idle at 1100rpm and 1200rpm.. is this normal?
Old Feb 5, 2008 | 08:03 PM
63HMOOB's Avatar
Default Re: (dc2_916)
make sure your throttle calbe isn't sticking. did you make sure you clean off the old gasket really good and used a new one.
Old Feb 5, 2008 | 10:03 PM
Default Re: (63HMOOB)
yah connect that vacuum line to where i told you to and your problem should be fixed so it wont bounce any more and your idle will go down to abot where its suppsed to
Old Feb 5, 2008 | 10:09 PM
all-mtr-teg's Avatar
Get some cams and a tune.
Old Feb 6, 2008 | 03:37 AM
denraweb's Avatar
Do this if you hear air being sucked in or blown out...
Grab a spool of thread (for like sewing and whatnot) and unwind it about 2 feet, but don't cut it. Now with your car running and you under the hood, hold the thread over different places of the manifold while holding the throttle open to where you can hear the "shh shhhhhh", but hold the spool tightly so it won't suck in too much thread. If the thread is sucked in a certain area, then you know that's where your leak is coming from. If it seems to blow the thread away at a certain point, then that is also a leak...good luck!
Old Feb 6, 2008 | 06:18 AM
TomsDC's Avatar
another way to check is with the car running take some starting fluid and spray it around the vaccum lines and ITM and if the idle jumps up thats where the leak is.
Old Feb 6, 2008 | 07:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_916 &raquo;</TD></TR><TR><TD CLASS="quote">i got short comtech short ram intake .stage 1 crower cams,unorthodox cam gears,dc header 4-2-1,dc 2.5 cat back exhaust,and the skunk2 IM. i dont kno anywhere i can tune it up at. i live in sacramento, CA.. ha.. but turnin the dizzy back in the midlle did stop the lagg . haha. </TD></TR></TABLE>
That's another reason you car may be lagging, vtec is not set at the best point and you're running an im that the stock ecu is not tuned for.
Old Feb 6, 2008 | 11:57 AM
dc2_916's Avatar
Default Re: skunk2 IM making me lagg (all-mtr-teg)
vtec kicks in really loud at 4800 rpm.. and it pulls hard when it reaches 6k rpm.. i found that today it was a vaccum leak i fixed my problem and now its runs like it use to be... A BEAST!!! muahha
Old Feb 6, 2008 | 02:26 PM
SuckMyDOHC's Avatar
Midnight Performance
http://www.midnightperformance.com/
They're located in Rancho Cordova. I don't know why their website says that they're in the Bay Area
Old Feb 6, 2008 | 03:10 PM
If you think it pulls hard now, wait till you get a tune, the stock vtec cross over is too low for aftermarket cams. You'll feel a big difference once its tuned
Old Feb 6, 2008 | 03:51 PM
dc2_916's Avatar
what does tuning mean? haha aint there like different knida tuning? dyno tune up and ****?u kno where i can get a tune at? i live in sac ca
Old Feb 6, 2008 | 04:00 PM
SuckMyDOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_916 &raquo;</TD></TR><TR><TD CLASS="quote">what does tuning mean? haha aint there like different knida tuning? dyno tune up and ****?u kno where i can get a tune at? i live in sac ca</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">
They're located in Rancho Cordova. I don't know why their website says that they're in the Bay Area</TD></TR></TABLE>
I just told you where to get it tuned it...
Old Feb 6, 2008 | 04:04 PM
Rickdrizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_916 &raquo;</TD></TR><TR><TD CLASS="quote">vtec kicks in really loud at 4800 rpm.. and it pulls hard when it reaches 6k rpm.. i found that today it was a vaccum leak i fixed my problem and now its runs like it use to be... A BEAST!!! muahha </TD></TR></TABLE>
so you're running a stock ecu with the s2 manifold and you think it pulls hard?
Old Feb 7, 2008 | 08:08 AM
dc2_916's Avatar
Default Re: skunk2 IM making me lagg (Rickdrizzle)
yeah.. still pulls harder then the stock manifold.. haha oh yeah and yesterday i jus got smoked by a modded ss camaro.i took off on 1st and second he came bak and whoop the **** outtah me.. prolly 5 cars from a digg. haha. i SEAFOAMeD my car yesterday and it runs alot better. i reccomend it.. u can get it at autozone for 7 buks.ha
Old Feb 7, 2008 | 08:12 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_916 &raquo;</TD></TR><TR><TD CLASS="quote">yeah.. still pulls harder then the stock manifold.. haha oh yeah and yesterday i jus got smoked by a modded ss camaro.i took off on 1st and second he came bak and whoop the **** outtah me.. prolly 5 cars from a digg. haha. i SEAFOAMeD my car yesterday and it runs alot better. i reccomend it.. u can get it at autozone for 7 buks.ha</TD></TR></TABLE>
random....plus you get a big for street racing
Old Feb 7, 2008 | 10:04 AM
I doubt an untuned gsr motor w/ aftermarket cams and s2 IM will pull that much harder than a stock motor. If anything your car is probably slower now than before the mods w/o a tune. And what the hell are you thinking even going up against a modded ss camaro
Old Feb 7, 2008 | 11:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote"> And what the hell are you thinking even going up against a modded ss camaro </TD></TR></TABLE>
if he wanna race the ss camaro let him lol, i raced a vette with a lot of stuff done to it... but then again im fully built turbo... but to the op, id get a tune now because then your car WILL pull a lot harder then now...
jyracer
Oct 14, 2008 12:17 PM
94lspower
May 9, 2007 02:53 AM
Civic98KH
Apr 25, 2007 08:32 AM
importtuner07
Aug 10, 2006 10:07 AM
Boostfed
Aug 1, 2003 07:43 AM
