clutch going soft
Old Feb 5, 2008 | 01:48 PM
94DB8's Avatar
Default clutch going soft
does anybody else have problems with their clutch losing fluid slowly?
Old Feb 5, 2008 | 06:08 PM
94DB8's Avatar
bump
Old Feb 5, 2008 | 06:14 PM
Hondas_Only's Avatar
check your slave cylinder. get a friend to press the clutch petal while you look at the cylinder. see if there is a slight drip drop... there's your answer. or check to see if you have fluid leaking under your steering column, then its prolly the master.
if the petal is going soft, try bleeding the clutch. that should stiffen it right up. (you'll need a friend for that too)... good luck
Old Feb 5, 2008 | 09:05 PM
ZE12O's Avatar
Default Re: (Hondas_Only)
sounds like a malfunctioning master or slave cylinder.
bleeding and changing fluid didnt help mine, the fluid would run out after a week or two even after bleeding.
you need to look for leaks and fix it or replace both.
(if ones going bad, the other shouldnt be too far away from going bad)
then again why change something that still works
deeweezy187
Jan 5, 2008 10:04 AM
ej1-usdm
Dec 5, 2007 04:03 AM
WiLLMaTiX
May 3, 2004 03:24 PM
94TeGsR
Jan 14, 2003 09:00 AM
John
Jan 16, 2002 12:38 PM
