which tranny to get...
Old Feb 5, 2008 | 11:48 AM
ls19integra95's Avatar
Default which tranny to get...
i was wondering which tranny would be the best for my fully built turbo ls... i will be using as a dd but also at the track where it will be running a rediculous amount of boost for track... type r, gsr, or ls...
Old Feb 5, 2008 | 11:54 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: which tranny to get... (ls19integra95)
B16A, either Type R , GS-R
Old Feb 5, 2008 | 11:59 AM
Default Re: which tranny to get... (mcvtec)
whats the difference between the b16a and the type r?
Old Feb 5, 2008 | 12:12 PM
BryanM.'s Avatar
Resident Gearhead
Not a whole lot really, Hype R has a little bit shorter gearing and usually co$t$ more.
Old Feb 5, 2008 | 12:16 PM
does the b16a have lsd though?
Old Feb 5, 2008 | 12:42 PM
b18b1turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">does the b16a have lsd though?</TD></TR></TABLE>
the usdm b16 dont but the jdm b16 does
Old Feb 5, 2008 | 01:00 PM
mr.beeks's Avatar
Default Re: which tranny to get... (b18b1turbo)
is your turbo custom made?
if you got shorter gears means that you will shift quicker and will not get the full potential of your turbo. vtec
if you got longer gears means you will shift slower and get the full potential of your turbo. ls
did you check the force induction section here?
Old Feb 5, 2008 | 01:08 PM
Default Re: which tranny to get... (mr.beeks)
i have a custom turbo kit, the turbos 1.15ar exhaust and .60ar intake side... it starts spoolin at just over 3k rpm... i found a type r that has a 4.4 final and another with a 4.78 final... you think either those would be ok? and no i havent tried forced induction yet, i figured id try here first since this isnt really completely forced induction related...
Old Feb 5, 2008 | 03:10 PM
Rikter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">is your turbo custom made?
Ahh someone with brains!
I agree 100%. LS trans (put an LSD in there) for turbo'ed vehicles and the shorter gears GSR/B16/Type R trans for all motor builds.
Longer gears = stay in boost longer.
-Rik
Old Feb 5, 2008 | 03:29 PM
SleeperGSR's Avatar
Default Re: which tranny to get... (Rikter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">
-Rik</TD></TR></TABLE>
I would agree with this.
But, it really would depened on your application. And since you can't change the gear ratio every day you will want to take a look at what you will be doing most of the time and pick the transmission for that. I would recomemend the GSR for a dd with maybe a final drive swap. Do some research and see what you want. I've read a million pros and cons about the different tranny's on here. From what i gather the ls is pretty much junk, maybe you could give that a final drive swap and get what you are looking for. 16 for top acceleration, and gsr for best of both worlds
Old Feb 5, 2008 | 04:02 PM
Default Re: which tranny to get... (SleeperGSR)
well i found the ratios for the ls, type r, gsr, and b16a
b16a
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3.000
Final Drive: 4.400
ls
1st: 3.230
2nd: 1.90
3rd: 1.269
4th: 0.966
5th: 0.714
Reverse: 3.000
Final Drive: 4.266:1
gsr
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.787
Reverse: 3.000
Final Drive: 4.400
type r (b18c5)
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3.000
Final Drive: 4.400 or 4.78
type r (b18c)
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.034
5th: 0.787
Reverse: 3.000
Final Drive: 4.785
i can also pick up and swap the final out on either of the type r ones with one that makes it 4.06 for the final drive and is for making it real good for turbo...
thanks for the input so far everyone, definetely a lot of things i gotta look at tonight and try figuring this out... but keep the advise and input comeing
Old Feb 5, 2008 | 07:10 PM
up...
Old Feb 5, 2008 | 09:27 PM
jdm tommy's Avatar
id go with the type r tranny
Old Feb 5, 2008 | 11:19 PM
91smashbox's Avatar
your going all turbo right? no nOs? cause da B-16 is perfect for sqweezing
Old Feb 6, 2008 | 03:56 AM
jdmjunkie8's Avatar
Default Re: which tranny to get... (91smashbox)
I would go with the LS trans and buy a LSD, B16 trans you would be shiftin every second.
Old Feb 6, 2008 | 05:19 AM
Dogginator's Avatar
Daisy... Daisy...
Unless traction is an issue, shorter gears will help, not hurt acceleration. By your "reasoning", you should shift into 5th a quickly as possible to enjoy the spooled turbo. The best transmission choice would depend on the OP's WHP. Have any of you asked that question, or do you simply want to regurgitate canned and fundamentally flawed statements?
Regarding gear ratios and transmission features, see this link:
http://www.ff-squad.com/tech/temp/Bgears.htm
Old Feb 6, 2008 | 05:49 AM
INTEGRA TYPE-XI's Avatar
ITR as bigger bearings then B16A and as an LSD. But with 4.40 or 4.785 FD as a fd I recomend a ls 5th gears..wont affect your time @ the track but will save you gas on the highway.
Hatcheys314
Oct 20, 2009 11:26 PM
mars-EF-LS
Jun 21, 2007 01:50 AM
Boring
11
Feb 17, 2005 09:34 AM
one slow eg5
Sep 22, 2004 06:12 PM
AzntstyleZ
May 19, 2003 08:54 AM
