Knew I had a valve cover leak but.../need semi urgent help
I knew I had a valve cover leak so I ordered a new valve cover gasket kit this morning. The paint was looking kinda ratty and I happened to have some paint stripper, paint and the afternoon free so I said WTH :cool:. Went to pull out the plug wires and one of them came out covered in oil so know I am WTF? :eek: Pull of the valve cover and I look in the #4 spark plug hole and I can see oil up almost to the top of the plug so now I am WTF!
So my question is HTF? do I go about getting the oil out of there so I can drive my car?
Twist up a paper towel and shove it in there a few times until you get most of the oil. If you have access to compressed air, blow it out (it's messy, but you can make it work without spraying it everywhere if you're not retarded). If you have a garden hose, you can shoot that in there until the oil floats out.
Your best bet, though, is the paper towel trick. Be sure to replace your gaskets afterward, as that's why the oil got in there in the first place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">after u clean up the messy oil, u will need to replace spark plug seals..4 of them</TD></TR></TABLE>
Already knew that and if you read the first post I have already ordered a new valve cover gasket kit.
I only need ideas to get the oil out of the spark plug hole.
Someone just mentioned to me a vacuum bleeder might work. Don't have one but I have been planning on buying one, now looks like it might be a good time.
I only need ideas to get the oil out of the spark plug hole. Someone just mentioned to me a vacuum bleeder might work. Don't have one but I have been planning on buying one, now looks like it might be a good time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Salami »</TD></TR><TR><TD CLASS="quote">I wound up using a drinking straw and a syringe. There was 2" of oil in one of the holes.
</TD></TR></TABLE>hahaha awesome
that is a lot though...
i guess i would have had to have seen it to know the paper towel would not have worked.
that is a lot though...i guess i would have had to have seen it to know the paper towel would not have worked.
dwllama
Jan 30, 2012 09:20 PM
BEYAAAH
Jun 4, 2007 11:17 AM
