Removing Front Sway bar... Need Help!
Old Feb 5, 2008 | 09:24 AM
Morasso's Avatar
Default Removing Front Sway bar... Need Help!
Hey guys,
I'm replacing my front driver side LCA, and I can't get my front sway bar off of the old LCA.
If I try to turn the nuts the whole assembly just spins, and if I try to hold one nut in place, while turning another I start to strip the nuts.
Can anyone help me out? this is a big pain in the ***!
This is on an EG by the way
Old Feb 5, 2008 | 09:34 AM
Morasso's Avatar
Default Re: Removing Front Sway bar... Need Help! (Morasso)
Heres a pic of what i'm talking about, sorry its real shitty, I forgot to put it on macro mode... I need to get this assembly out!
Old Feb 5, 2008 | 09:53 AM
Cln94EG1's Avatar
If your just removing the front LCA u dont have to remove that theres like only 5 bolts to take out and then it come right now
Old Feb 5, 2008 | 10:08 AM
96GSRcx's Avatar
Default Re: Removing Front Sway bar... Need Help! (cln92eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morasso &raquo;</TD></TR><TR><TD CLASS="quote">
You start to strip the outside of the nuts or the threads on the bolt?
Old Feb 5, 2008 | 10:16 AM
instrument's Avatar
i have no idea why you're taking that off to remove the LCA
the LCA completely disconnects from that arm without removing the sway bar.
or are you changing the whole assembly?
there are two bolts that hold the lca to that a arm thing, remove the one from the ball joint, and the one that attaches to the car and it'll slide out, and put on the new arm.
Old Feb 5, 2008 | 10:29 AM
Relic1's Avatar
His reason for this.... https://honda-tech.com/zerothread?id=2214444
cut bolt at the nut, throw everything but the sway away.
buy poly setup from parts store for $20.
Old Feb 5, 2008 | 10:55 AM
MMastro's Avatar
You got to love working on old rusty cars... I can't wait to start on my '93 civic project after just swapping a '00 Subaru that was in RI its whole life rusting away.
Once the nuts stripped you have to use a damaged nut/bolt remover socket or cut it off as said...
http://www.sears.com/shc/s/p_1...moval
Old Feb 5, 2008 | 12:43 PM
Morasso's Avatar
Default Re: (MMastro)
I ended up getting it off.
I was using a 1/2" wrench and socket, switched to a 12mm and it came right off...
Old Feb 5, 2008 | 02:06 PM
Relic1's Avatar
Default Re: (Morasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morasso &raquo;</TD></TR><TR><TD CLASS="quote">I ended up getting it off.
I was using a 1/2" wrench and socket, switched to a 12mm and it came right off... </TD></TR></TABLE>
wait wait wait... you were using a 1/2" wrench on a honda?
dtran002
Nov 6, 2007 05:51 PM
ZipTieGUy
Apr 29, 2006 10:17 AM
igo4bmx
Suspension & Brakes
Mar 19, 2006 10:15 AM
redryder
18
Aug 27, 2005 12:14 PM
mystikz2002
May 7, 2005 09:00 AM
