pistons 2,3,4, TDC?
Old Feb 5, 2008 | 09:13 AM
obuhmyuh's Avatar
Default pistons 2,3,4, TDC?
i know how to get piston #1 at TDC but im confused on getting the other 3 there. im doing a valve adjustment today and need to get them there. so far i've found https://honda-tech.com/zerothread?id=1305086 which says how to adjust them, but i am still unclear on the TDC for the others...
thanks
Old Feb 5, 2008 | 09:22 AM
crazyguy's Avatar
Default Re: pistons 2,3,4, TDC? (d[sick]sTeena)
single cam or dual cam?
u can line up the tdc mark from crank pulley to lower timing belt cover. and turn crank pulley counterclock wise until up arrow facing up thats piston 1 and then turn crank pulley uncounter clock wise, until up arrow facing left thats piston 3. and the up arrow down is pistons 4..the up arrow to the right is piston 2
Old Feb 5, 2008 | 09:24 AM
obuhmyuh's Avatar
Default Re: pistons 2,3,4, TDC? (crazyguy)
to find tdc for cylinders 2,3,4?
Old Feb 5, 2008 | 09:30 AM
crazyguy's Avatar
there is no direct tdc marks for pistons 2 ,3 and 4..u have to turn crank pulley to match the tdc marks on the cam gear for piston 2,3,4
Old Feb 5, 2008 | 09:51 AM
rivaladore's Avatar
1. take out the spark plugs
2. put a wooden dowel or something similiar in the hole
3. turn crank till your ("piece of whatever" is at its highest point)
4. bingo, that cylinder is at TDC
Old Feb 5, 2008 | 11:47 AM
obuhmyuh's Avatar
Default Re: pistons 2,3,4, TDC? (rivaladore)
thanks my haynes manuel actually had a better way. #1 tdc w/up at top. cyl #4 w/top at 9 oclock or something like that, i left the book downstairs. and so on and so forth doing that.
Old Feb 5, 2008 | 12:02 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d[sick &raquo;</TD></TR><TR><TD CLASS="quote">sTeena]thanks my haynes manuel actually had a better way. #1 tdc w/up at top. cyl #4 w/top at 9 oclock or something like that, i left the book downstairs. and so on and so forth doing that.</TD></TR></TABLE>
didnt i say the exact same thing on my second post? the up arrow points to left 9 oclock and right 3 oclock ?
Old Feb 5, 2008 | 12:04 PM
obuhmyuh's Avatar
kind of, i was already done by the time you posted that, and the "oclock" phrasing helped me out more.
Old Feb 5, 2008 | 12:05 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d[sick &raquo;</TD></TR><TR><TD CLASS="quote">sTeena]kind of, i was already done by the time you posted that, and the "oclock" phrasing helped me out more.</TD></TR></TABLE>
cool
Old Feb 5, 2008 | 12:19 PM
Syndacate's Avatar
Turn 90* CCW off of 1 at TDC to get 2 to TDC, another 90* to get 3 to TDC, another 90* to get 4 to TDC.
Old Feb 5, 2008 | 12:41 PM
obuhmyuh's Avatar
Default Re: pistons 2,3,4, TDC? (Syndacate)
also another good way to describe it. thanks
honda fan forever
Classic Hondas
Sep 12, 2008 08:17 PM
T--Rex
Oct 21, 2004 05:49 PM
optoomistic
Oct 27, 2003 03:48 AM
B18 civic
Oct 5, 2002 04:59 PM
dpo95si
Aug 17, 2002 08:11 AM
