Problems with my CD coupe input please
Old Feb 5, 2008 | 08:49 AM
JuNkDoGAccOrD's Avatar
Default Problems with my CD coupe input please
hey guys i am having a few electrical probs i guess and they have me kinda stumped. First i have a 94 coupe and when i manualy lock my car form the outside with my key it seams that the auto lock actuator i guess locks the door but then keeps on clicking like if it was still trying to lock. It will stay clicking like that for about a minute then stop ???? WTF it has never done that before and and now it just goes crazy every time the door locks..... Second now mind you this all just started happening within the last few days, my car is a 5 speed so i engage the e-brake handle when i park my car. that means that the "BRAKE" light come on in the gaue cluster well now when i take off the e-brake the "BRAKE" light stays on ???? any and all input will be very appreciated from all u guys
Old Feb 5, 2008 | 11:07 AM
bseriescrxsi's Avatar
Default Re: Problems with my CD coupe input please (JuNkDoGAccOrD)
well with the BRAKE light staying on after you release the e-brake means your probably low on brake fluid which means you have a leak somewhere as for the lock actuator it could be the actuator itself or and electrical problem
Old Feb 5, 2008 | 05:11 PM
steerh67's Avatar
Default Re: Problems with my CD coupe input please (bseriescrxsi)
the brake light on does not always mean you are low on brake fluid. This switch on the handle itself may be stuck, making the computer think the e-brake is still engaged.
Old Feb 5, 2008 | 06:26 PM
TheMuffinMan's Avatar
He knows where you live!
1) is a dying door lock actuator
2) is probably the switch
Old Feb 5, 2008 | 07:34 PM
Default Re: (TheMuffinMan)
the switch on the e-brake is the little connector on the bottom of it ???
Old Feb 5, 2008 | 08:33 PM
UnIpHyEdAcCoRd's Avatar
Default Re: (JuNkDoGAccOrD)
I had the same problem with my door locks, like everyone said; it's the actuator. I took it apart and found out there was a little piece of rubber that over times breaks which causes that sound of continuous locking, eventually the motor will die out on it. Just replace it and you'll be fine.
Old Feb 6, 2008 | 07:02 AM
well the "BRAKE" light was the fluid i guess i wil have to check for leak thank for the input...... Next on the list is he lock prob
Old Feb 10, 2008 | 02:18 PM
Ok if i have a dying actuator on one door would one effect the other ???? Because both doors are doing the same clicking sound. Does that mean that both have to be changed out or would fixing one help the other ???
hikaps14
Honda Civic (2001 - 2005)
25
Aug 30, 2013 09:56 PM
92EG8
Jun 22, 2009 08:43 AM
GT_Alpha
May 8, 2005 08:21 PM
nemesismachine
Jul 21, 2004 07:00 PM
knucklehead11
May 25, 2004 04:52 PM
