disk break convertion , parking break
Old Feb 5, 2008 | 08:47 AM
raulduke's Avatar
Default disk break convertion , parking break
ok, so i just finished doing the rear disk swap on my 1997 civic ex coup, and i was woundering if there was any way of telling a 40/40 proportion valve from a 30/30 i picked up a prop valve from the honda junk yard guys, how ever i dont trust them 100% . i could be just putting another ex prop valve on...also arnt the rear disks sposto lock up when you pull the e-break hard..it just creeps to a slow roll, maybe new calerpers would help, there were hard as hell to twist back enough to get my new pads on.. i cant remember if my drums locked or not..
Old Feb 5, 2008 | 08:51 AM
Luserkid's Avatar
Default Re: disk break convertion , parking break (raulduke)
Did whoever install your adjust the ebrake cable? Im going with no because you say you creep forward (are you doing this while your burning out?). Go back to whoever installed them and have them adjust them.
Old Feb 8, 2008 | 08:59 AM
raulduke's Avatar
i got the break cable adjusted, how ever only the pass side locks up... can it be adjusted more ive got it pretty tight on the equalizer bar ...
Old Feb 8, 2008 | 09:03 AM
Probot's Avatar
Default Re: (raulduke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raulduke &raquo;</TD></TR><TR><TD CLASS="quote">i got the break cable adjusted, how ever only the pass side locks up... can it be adjusted more ive got it pretty tight on the equalizer bar ... </TD></TR></TABLE>
your caliper could be seized up on the driver side - really inexpensive, easy fix.
Old Feb 8, 2008 | 09:26 AM
EG6SPOOLIN's Avatar
agree with probot!
Old Feb 8, 2008 | 10:01 AM
B18CivicEJ8's Avatar
As far as the prop valve, if it's oem from honda, there should be a stamp on it. Mine is clearly stamped 4040.
Old Feb 23, 2009 | 05:39 PM
raulduke's Avatar
Old Feb 23, 2009 | 05:46 PM
Redbone's Avatar
did u use the 99-00 si e-brake cables?
D21X
Jul 25, 2023 07:45 PM
90lsvcrxva
Suspension & Brakes
Jul 29, 2012 11:59 AM
951BRO
36
Jun 14, 2007 08:38 PM
slimjimdanny
Mar 21, 2007 10:07 PM
seancoleshill
Aug 7, 2006 03:05 PM
