Oil pressure bypass help asap
From the ECU plug, cut the vtec pressure switch wire(D6) and tap it into the VTEC solenoid wire(A4). I do this for all the JDM swaps. No cel and vtec works.
Make sure you have sufficient oil though. The pressure switch is the sensor that decides if you have enough oil to cross over to vtec. This method bypasses it.
or you can buy one from me
94wip
12
Jun 20, 2024 07:23 PM
DoHc-
10
Nov 10, 2014 01:02 AM
