P30 ECU Problem, car won't start
Old Feb 5, 2008 | 08:01 AM
silverbur's Avatar
Default P30 ECU Problem, car won't start
Hi, I just wanted to check on the site to see if anyone can tell me about the problem I'm having. I have a P30 from a del Sol Vtec with a weird problem. I get the check engine light and the fuel pump gets no power so the car wont start, we scanned the car and got no error codes. We tested the ecu and think that the problem is on the start module, I installed a chip on the ecu to see if that could solve the problem but it is the same, check engine light. Before that I checked the main relay and it is ok. Can anyone tell me what could be wrong with the ECU?? Is it possible to fix it? where can I find the full diagram to check the start module, where's that module located?? can I replace it? fix it? Thanks in advance!!
Old Feb 5, 2008 | 11:47 AM
ironcheftony's Avatar
sounds like your ecu died, happen to a friend of mine as well with a p30, time for a new ecu
Old Feb 5, 2008 | 12:19 PM
silverbur's Avatar
Default Re: (ironcheftony)
I already have a new one, I just want to try to save that ECU...I installed a chip to try to save it but is not working...any ideas?
Old Feb 5, 2008 | 01:42 PM
i believe you can try to change one of the main capacitors or whatever might have gone out, sometimes it works sometimes it doesnt, take the chip out and and put it in your new ecu,
good luck saving the ecu
Chriseh9
Dec 10, 2018 06:49 PM
B16-CRX
Engine Management and Tuning
26
Jul 2, 2011 02:25 PM
bare
15
Aug 13, 2005 06:23 PM
Infinity_Racer
11
Jul 25, 2002 06:09 PM
