91 ef swap
From: ORLANDO AKA WATCH YOUR HONDA OR ITS GONE, FL, USA
i just got a red 1991 ef hatch and i need a swap badly!!! it still has the stock single cam motor with wak *** dual port
at the moment cant afford a B16, what i really want. i was thinkin of droppin an ls in it but not that many people in my area know how to mess with the wire harness. and the people that do know how to do it are the theifs and i really dont want them to be around ma car like that. so what do you guys suggest. if you know any one or could send me a diagram cuz i cant find it on here lmk. im located in orlando fl
You can't afford a B16 but can afford an LS? There's not that much of a difference in price between them.
There's plenty of wiring info in the FAQ. You'll need to convert to MPFI then mod the harness to work with the new motor (and adding VTEC if you get the B16). Get to reading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itznuffinman1 »</TD></TR><TR><TD CLASS="quote">thanks but in florida ls motors are nothing to these theives. they let those go for mad cheap. but thanks anyway</TD></TR></TABLE>does this mean you will be buying a stolen LS engine? if so, i don't think you will get much help here - most people on here frown on this sort of thing - i don't know how it is in Fla but around here, engines purchased from a thief are the first ones stolen, because you can't do anything about it
I WOULD NOT BUY A STOLEN MOTOR. I PROLLY PRESENTED IT WRONG I MEANT TO SAY THAT THEY STEAL GOOD MOTORS AND AT THE MOMENT I CANT AFFORD TO GET A B16 ESPECIALLY IF THEY GONNA STEAL IT.<----BETTER WORDS. I WANT A LS FOR NOW CUZ I KNOW THEY WONT BOTHER IT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itznuffinman1 »</TD></TR><TR><TD CLASS="quote">I WOULD NOT BUY A STOLEN MOTOR. I PROLLY PRESENTED IT WRONG I MEANT TO SAY THAT THEY STEAL GOOD MOTORS AND AT THE MOMENT I CANT AFFORD TO GET A B16 ESPECIALLY IF THEY GONNA STEAL IT.<----BETTER WORDS. I WANT A LS FOR NOW CUZ I KNOW THEY WONT BOTHER IT</TD></TR></TABLE>good enough - that sounds better - with any B-series swap you will end up spending $800-1000 more than the cost of the engine just to get it in - you will need a transmission, a mount kit, shift linkage, axles, exhaust, probably new clutch, etc. - if money is a problem, you would be better off sticking with a D-series swap like SOHC VTEC, DOHC ZC or just a D16A6 Si engine - you can get it in pretty cheap and then improve it as you get the money, like getting different exhaust, Si transmission, etc.
TRUE I COULD DO THE SWAP FOR CHEAP ITS JUST THAT EVERY ONE AROUND MY WAY IS A EG D*** RIDERS AND NO ONE KNOWS ABOUT EFS. THERE IS LIKE 10% EFERS OUT HERE AND THEY HAVE SOMETHING SO SERIOUS THAT THEY THINK THEY COULD CHARGE YOU AN ARM AND A LEG
You shouldn't care what other people think of your car. Let them ride EG dick.
Do the MPFI swap on your DX engine as an inexpensive start, then go from there.
i got my dx ef hatch that had already been converted to mpfi- i've had several dual points and for obvious reasons always hated them. i never thought a 1.5 dx would go as well as it does when converted to mpfi, 3rd gear hill climbing and cruising comfortable at 30mph in 5th, saving gas and definetly enough power. multi point's got to be a cheap conversion, i've never done it myself just on a single, only to prep for a b-series, so just doing that alone to your d-series will give impressive results IMO, then you can get a z6/y8 head and p28 and all of that, keep your stock valve cover, and have a little mini-me without "d16__" stamped on the block, if you care about people thieving your d-series.
dseries motors are under-rated, and easy to hate on because it's what your car came with and someone else's b-series ef seems cooler. not always the case, saving money and doing your own thing can be much better than paying whatever it takes to have a "cool" car or setup. at the end of the night, if you've done what you want, how you want, THAT should be a lot cooler to you than impressing people.
(my two cents)
(my two cents)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigrob119 »</TD></TR><TR><TD CLASS="quote">You shouldn't care what other people think of your car. Let them ride EG dick.
Do the MPFI swap on your DX engine as an inexpensive start, then go from there.</TD></TR></TABLE>
um.. u want an ls so they will leave your car alone? make sure you pop em in the nutz next time you see them....and definetly strart with an mpfi conversion. this will give you time to save money ,and to pick what motor your gonna want
I can help you out if you need to convert to mpfi or do something else to your car....
I live in Orlando too and I bought a 91 Civic HB dx last month. I am going to but a full b16 obd0 swap next month.
So if you need info or help let me know......
^^^^^^(jun) you stay in orlando? then you should no how they are out her!!! just let me know i wanted to do it soon but i need a new ecu, crx si distributor, and a fuel rail. let me know if you got any of these
dude just save your self the hassle of doin the wireing and send the cores to hasport!! thats what i did when i put an a2 swap in crx... their a lil expensive but they get the job dont right the first time!!! its been three months since i did my swap and i still had any problems with any of their products!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCVTEC4life »</TD></TR><TR><TD CLASS="quote">dude im am in the same situation i just got a 1991 red civic dx for 400 runs fine stripped out and it is dual port im goin to change it to pgmfi</TD></TR></TABLE>
It already is PGMFI.
You want MPFI.
You want MPFI.
ghettoda9
Mar 8, 2012 05:12 AM
