91 Honda automatic trans. problem
Old Feb 5, 2008 | 03:09 AM
gomezclan's Avatar
Default 91 Honda automatic trans. problem
Some times the shifter in my 91 Accord will not go out of park after I start. When this happens I have to turn off the car and put the key in the swift lock release . The car swift fine when I an driving, any help would be helpful.
Dave
Old Feb 5, 2008 | 09:33 AM
HennessyLane's Avatar
Default Re: 91 Honda automatic trans. problem (gomezclan)
I have the same problem on my 91 accord EX. I have to do the samething or unplug the batt for a min it's the trans computer in mine don't just stay in 1st i have to change it 1,2,3,4 evertime i stop i have to change it back to 1st myself. just get a new trans computer try not to get one that was made in Suwanee, Georgia.
Old Feb 5, 2008 | 05:30 PM
hondadude's Avatar
do your brake lights work?
There is a shift interlock under the center console you should hear it click when you step on the brake.
Check your brake light switch, the other problem could be the interlock solenoid.
they can get gummed up with crud from coffee and cola spills in that area.
Old Feb 6, 2008 | 03:04 AM
gomezclan's Avatar
Default Re: 91 Honda automatic trans. problem (hondadude)
I was thinking is there a switch under the brake pedal. This is an intermittent problem, when this happened last time I just had to press the brake harder and it would go into drive. Thanks for all the help.
Dave
Old Feb 7, 2008 | 02:55 AM
gomezclan's Avatar
I'm able to shift out of park now. I pressed really hard on the brake pedal and now it works fine for now. If anybody has any other suggestion on haw to kow to keep from happening again that would be helpful.
Thanks,
Dave
thrasherx
Jun 23, 2024 04:22 AM
mrmyass
Mar 11, 2015 11:02 AM
firemansteve
Oct 1, 2007 05:44 PM
khaperey
Aug 23, 2006 05:18 PM
drunkinmiami
Nov 19, 2005 12:52 PM
