i was dirvin the other day i spun out n now when i drive i got this bumpin noise help me out!!!
Old Feb 4, 2008 | 07:33 PM
CivicPImp90's Avatar
Default i was dirvin the other day i spun out n now when i drive i got this bumpin noise help me out!!!
ok i was drivin on the highway n spun out i didnt hit anythind just spun. when i drove away i noticed that my car was making a bumpin noise . i have bo ideal what it is???
Old Feb 4, 2008 | 07:38 PM
ahron's Avatar
Default Re: i was dirvin the other day i spun out n now when i drive i got this bumpin noise help me out!!!
ur tires?
Old Feb 4, 2008 | 07:42 PM
yeah it might be the back i gota bent rim back there but could spinnin out bend my axel or worse ???
Old Feb 4, 2008 | 07:56 PM
crimsonv4mpire's Avatar
if you feel it bump and pull the car at the same time i'd check the wheel bearings. jack the car up and grab top and bottom of the wheel and try to shake slowly, then both sides and try to shake that way, if there is any play that could be the answer
Old Feb 4, 2008 | 07:58 PM
Old Feb 4, 2008 | 07:59 PM
ahron's Avatar
.. i dont know. it happen to me to a couple weeks ago.. i spun on the freeway but wanst hit. im hearing and feeling a little bumps too.. i think its my tires. my tires sucked on the first place.. i burned rubber.. and the tire is kind of messed up.. i think its the reason..i havent changed my tires yet.. i got stock rims and i might as well get new ones while im at it
Old Feb 4, 2008 | 08:02 PM
spivt11's Avatar
* B A N N E D *
check your struts and shocks as well. A blown strut will give you a bumpy ride and you can usually spot a blown one visually (lots of oil in your wheel well)
Old Feb 4, 2008 | 08:04 PM
c im chinged my rear tires when i got it n my front rnt thta bad my rims bent though how fast were you goin when you spun out
ahron's Avatar
this could be a good reason
Old Feb 4, 2008 | 08:06 PM
how much r the berings if that the problem
Old Feb 4, 2008 | 08:08 PM
i swapped out my front rims n nothin changed it might be my rear i dono so like my axel cant be bent if i didnt hit anything
ahron's Avatar
70 maybe.. not too fast... ur rims are bent?
titosek4
Suspension & Brakes
Sep 29, 2011 05:02 PM
S2Kstuntin
Jan 17, 2010 01:19 PM
tdc
Jun 29, 2003 05:57 PM
RagingAngel
Oct 3, 2002 01:27 PM
