what else to buy with new clutch
Old Feb 4, 2008 | 07:17 PM
jr408's Avatar
Default what else to buy with new clutch
Im thinking about getting new clutches. what else would do you think i should buy with the new clutch? it comes with pressure plate, pilot bearing, throw-out bearing and the clutch alignment tool.I have a 98 acura integra ls
Old Feb 4, 2008 | 07:49 PM
j_bizach's Avatar
Default Re: what else to buy with new clutch (jr408)
nothing
Old Feb 4, 2008 | 08:12 PM
.xcalibur.'s Avatar
might as well buy a lighter flywheel.
Old Feb 4, 2008 | 08:30 PM
Rikter's Avatar
Or if you can't afford that, resurface the flywheel you have.
I'd suggest also buying tranny fluid.
-Rik
Old Feb 4, 2008 | 09:56 PM
Berlinetta F1's Avatar
buy a GSR trans with an L.S.D. in it. since you will have to take the tranny off anyway.
Old Feb 4, 2008 | 09:58 PM
Schister66's Avatar
Man U FTW
The only things you'll actually need, contrary to what some list above are as follows:
-Clutch disk
-Pressure plate
-Pilot bearing
-Throw Out Bearing (TOB)
-Clutch alignment tool
-Resurfacing of the old flywheel
Old Feb 4, 2008 | 10:02 PM
supracrx's Avatar
well since the tranny is going to have to come out, i would do the rear engine seal too. thats what im plan on doing when i do my clutch.
im going to change all the things listed above + rear engine seal, and possibly axle seal
s too....but thats me since parts only cost me about $5 more for those seals.
Modified by supracrx at 11:18 PM 2/4/2008
Old Feb 4, 2008 | 10:07 PM
Schister66's Avatar
Man U FTW
Good plan...those are cheap insurance
Old Feb 4, 2008 | 10:19 PM
supracrx's Avatar
i'll also be doing my oil pan gasket as well since its leaking....that will be easier since the tranny is out and i'll have access to three of the bolts that is somewhat covered.
Old Feb 4, 2008 | 11:11 PM
DownShiftPerformDC2's Avatar
i would suggest a magnetic trans drain plug too
leewal
Sep 10, 2006 11:37 AM
kr
Apr 21, 2006 05:31 AM
93FastLs
Sep 1, 2005 07:28 PM
CardDealer
Jun 6, 2004 03:10 PM
Angry Joe
Sep 12, 2002 09:07 PM
